AH FabricationsChris Nott
Results 1 to 10 of 10
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    Chesterfield, Derbyshire, United Kingdom
    612
    AUDI A3 1.8T EXHAUST
    HI ALL JUST WONDERING IF YOU COULD GIVE ME SOME ADVICE ON A EXHAUST. IM JUST WONDERING IF THE GOLF GTI 1.8T OR SEAT LEON CUPRA EXHAUST SYSYTEMS ARE THE SAME. REASON IM ASKING IS BECAUSE I HAVE SEEN NUMEROUS PEOPLE ADVERTISING EXHAUSTS SAYING THEY FIT ALL 3.
    THANKS
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,617
    stop SHOUTING
    Apr 2010
    Widnes Cheshire
    404
    Maybe you should contact the Vendor and ask for clarification.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    GOlf exhausts fit...but you need to trim the bumper and a bit of sheet metal behind it.. No big deal really.
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Yup, Golf exhausts fit. Here are some pics of where you have to trim
    The plastic on the rear lower bumper has to be trimmed to. Very easy to do.
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    I wonder if it's in the right position for a rear S3 bumber? Looks very close, IIRC, when I fitted my S3 rear bumper to my A3, the exhaust tailpipes had to be moved over about 4" to the right, if it does fit in exactly the same position, then it'll give me more options on rear exhausts available 'off the shelf' as the only option I currently have are custom made backbox [runs off to check exhaust alignment]...
    [Back again!]
    Yup, my exhaust tailpipes line up about an inch away from the spare wheel well and the pic above looks to be very similar... even the height of the tailpipes look as though they will be just perfect. Big thanks to HTC for the images posted!
    Imteyaz.
    AGU-TURBO's Avatar
    Audi a3 1.8t AGU
    Apr 2010
    612
    brilliant thanks very much
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    654
    i dont think that works for an S3...
    so how did you get the back box from an S3 fit your A3....im kind of lost here
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    Quote Originally Posted by Imteyaz View Post
    I wonder if it's in the right position for a rear S3 bumper?
    I only fitted an S3 bumper but used the exhisting A3 exhaust, had new tailpipe trims welded on after they extended the pipework to shift over 4" to the right as per S3.
    Imteyaz.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    I stuck an S3 rear box on the A3 TQS and it fitted into the S3 bumper cut out perfectly. The A3 box tail pipes lined up fine, but were down turned.
    Not sure if the 2wd Golf exhausts are the same fitment, but no reason to assume not
    edit, i had to cut the same section out as the pics, so i recon its a go er !!!
