Monster MotorsportChris Nott
Results 1 to 14 of 14
Like Tree7Likes
  • 1 Post By Andrew@A.L.D
  • 3 Post By fanta
  • 2 Post By Tim_Attard
  • 1 Post By <tuffty/>
Thread: A3/S3 FAQ / How To's / Tuning Info STICKIES - PLEASE READ BEFORE POSTING
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,506
    Use of the english language
    IMPORTANT! - When posting asking for help... - PLEASE READ BEFORE POSTING
    General Information,useful to all
    Always bleed your coolant system properly+check it when its cold.. Warning skin burns
    A3/S3 FAQ Look here for information before posting a questions
    I want to sell my car, whats it worth?
    S3 Buying Guide
    Injector Cleaning Guide
    S3 sump removal and refit
    Driveshaft gaiter replacement tutorial
    Active scammer, members beware
    Car Buyers beware-flaw in HPI mileage checks
    Audi a3/s3 workshop manuals
    Performance enhancements
    REMAPS: Everything you need to know about remaps....
    A3 1.6 to 1.8t conversion information
    A3 - Must do modifications for K03/K03s AGU and AUM engines FWD cars
    Benjamins S2000 air filter mod
    Jetex cone in S3 OEM airbox pt1
    Jetex cone in S3 OEM airbox pt2
    XS Power down pipes and manifolds for K04 turbos (S3, TT)
    Ess three's comprehensive engine testing
    AH Fab / Ebay / Forge S3/A3 FMIC installs (image heavy) **UPDATED with new v2 AH Fabs FMIC details**
    Big turbo and High power information
    1.8t Information sheet
    CR-K04-Stage-4-Hybrid-comparison-to-k04
    Hybrid turbocharger k04 build
    Got a K03(S) installed and want more bhp?
    SAI removal, How to for 8L A3 & S3
    N249 removal for 8L's S3 (APY) & A3 Complete how to
    How to: N249 Bypass - S3 AMK/BAM Engine
    N249 Bypass Guide for ARY Engine and all other A3 Engines
    How to Log with VAGCOM
    Guide - How to fit a catch can and simplify the PCV system
    A3 (K03/K03s) TIP fitting guide
    How to fit a Badger 5 80mm TIP
    Basic cylinder head porting guide
    S3 300mm rear brake conversion kit
    TFSI coil pack info....
    A little info for you on ARP bolts for people that want to fit them
    External problems and modifications
    How To: Audi S3 Fuel Pump Replacement (The cheaper way...)
    Haldex problems....
    ANTI-CORROSION WARRANTY RESULTS - PLEASE POST HERE
    Broken window? Window clips? Window regulator? or motor? Guide inside
    IMPORTANT ALL READ. Rusting bottom of doors, when will it be yours?
    headlight upgrade, is this the right choice...?
    How To: Fitting A HID Kit to A3 8L
    S3/A3 Headlamp Adjuster Removal / Refit
    S3 Suspension and Set-up Guide
    The-Definitive-Cheap-Ebay-Coilover-Thread-(Jamex)-With-how-to-guide
    Audi A3 ? S3 Bumper Conversion Parts & Part Numbers
    Rear tie bar replacement and adjustment on 8L S3 and A3 Quattro
    The definative brake thread for 8L chassied cars
    Aa3-aum 1-8t ebay fmic install
    how to use vagcom/vcds to test for boost / vac leaks
    Headlight restoration with pics
    Sump removal/fitting with pics... oil pick up clean
    Battery relocation ideas
    All you (probably) need to know about dump valves on 1.8t's
    Stripped my Forge dump valve down
    Interesting dump valve information...
    Electronics and diagnosis
    VCDS / VAG-Com Users-Map
    Liquid Diagnostics Gauge Review
    Internal modifications and How To Guides
    How to fit the new-S3-(8P)-Gearknob
    How to remove/fit S3 front bumper
    How to remove rear bumper.
    HOW TO: Fit cruise control to an A3 1.8T (pic heavy)
    Interior LED pack for 8L S3/A3
    How to: Ambient Lighting for cheap
    Replacing Broken Clutch Pedal - How to Guide (with pics)
    Double Din Conversion / RNS-D Retro Fit
    Fitting a Stack boost gauge while making it look OEM... (and a Liquid gauge...)
    How To: change the colour of a Stack gauge to make it more OE
    s3_Kev and his double pillar pod fitment...
    <tuffty/> and a single pillar pod plus Liquid Gauge fitting... pt1
    <tuffty/> and a single pillar pod plus Liquid Gauge fitting... pt2
    HOUCH's Avatar
    Aug 2006
    88
    Hi there just wondering if anyone can point me in right direction drivers side electric window of my 2001 a3 quatt decided to play up at the weekend went down and stopped before getting to the bottom, then when I tried to close window it goes up slowly then stops and goes down like it's detected something in the way and goes down inch or so before stopping, removed card at weekend could not see anything obvious no broken glass clips etc, greased/w.d'd runners and rubbers which made window go down fully and at normal speed even undid the 4 x hex headed bolts that hold window frame to door shell in case window out of shape, window did seem bit better after all this but still not right, today started going up and jumping down like before also speed going down is fine but very slow going up. I replaced door few weeks ago but window mech is the origional one which has not given me any problems before door swap or after...until now.
    They electric window motors are handed so pass will not fit onto drivers but the splines do line up so tried the passenger side on drivers window and was still slow going up so not sure if fitting new drivers side motor will cure prob, didnt want to go down the fit it and see route as always expensive so before go any further thought best to see if any of you guys have had simlar... sorry for waffle cheers for reading post...Houch
    Houch
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,436
    Quote Originally Posted by HOUCH View Post
    Sounds like broken window slips to me, common problem, and was in the FAQs above.
    Faulty S3 Electric Window Fix
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    i'm sure theres alot of "how to's" missing from here......top mounts
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    Quote Originally Posted by mattyboy199 View Post
    The list could be endless Matty but we generally put the common ones
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,454
    WorkInProgress likes this.
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Updated...
    <tuffty/>
    Jul 2013
    Uckfield
    111
    Follow fanta On Twitter Add fanta on Facebook Add fanta on Google+ Visit fanta's Youtube Channel Visit fanta's Instagram Channel
    Can I just point out that as a newbie to the forum and my a3, this is the best stickies thread I've seen on any forum ever! It's like a toy shop! Full of things I can play with!
    Thanks to all that have added to this! It's VERY appreciated!
    Sandra, MIGGZ and Tim_Attard like this.
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    FINALLY someone who read them :D
    Sandra and MIGGZ like this.
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    Jul 2013
    Uckfield
    111
    Quote Originally Posted by Tim_Attard View Post
    Although There needs to be more about audio here, for instance I've fitted a new HU and there is some feedback coming from the rear speakers, I ignored this as the sub worked lovely and everything seemed cool. Now the car won't start as I guess the HU has caused the battery to train (assumptions). Unless I'm missing the thread title with what I'm searching for...
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,254
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by fanta View Post
    That's not really anything specific to the 8L model though- that just sounds like the system hasn't been wired up correctly with the install of a new HU, sub, speakers and amps. So that's pretty generic for any car...
    There's a whole section dedicated to ICE related stuff where you can post for help on ASN -
    In-Car Entertainment
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Drewvic's Avatar
    Nov 2013
    North yorkshire
    203
    hi the vcds/vag-com thread on here isn't working any reason thanks
    1.8Q sleeper all the way
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Quote Originally Posted by Drewvic View Post
    Done....
    <tuffty/>
    Drewvic likes this.
    Drewvic's Avatar
    Nov 2013
    North yorkshire
    203
    Done....
    <tuffty/>
    thanks tuffty
  1. Replies: 13
    Last Post: 13th April 2011, 21:28
  2. A4/S4 FAQ - Look here first before posting questions
    By Kevint in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th February 2010, 16:17
  3. MODS PLEASE READ - stickies
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2009, 13:46
  4. Guide for posting How to's . .
    By Olly_K in forum General Technical / How To
    Last Post: 16th August 2006, 12:28
  5. A3/S3 FAQ - Look here first before posting questions
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2005, 09:32
