Monster MotorsportBadger5
    Apr 2010
    Basingstoke
    7
    Exclamation Help new cluch and flyheel needed
    I have been advised i need a new flywheel (and clutch and master cylinder while im at it) i am running approx 265bhp with cone filter and dv and have plans for stage 2 (second map and exhaust and sport cat) soon is it worth upgrading the clutch etc while im at it or shall i replace with genuine parts i am in two minds of keeping as daily driver or taking it that little bit further ( bigger turbo etc)...
    Any suggestions or help would be greatly appreciated as im a bit of a novice Thanks guys
    May 2010
    151
    Im in the same boat as you matey, Just had a map done and im worried about clutch as its done 110k !. Im just going to bite the bullet and buy a helix clutch and lightweight flywheel !. It comes out expensive but your pretty much set for whatever the future brings !.
    You can get away with running standard clutch , There are a few on here running big power through them however just hold of the launches ! .
    Its up to you really bud if you can though i would save and go for helix or sachs, im sure there the options you will get pointed towards on this forum :D.
    Apr 2010
    Basingstoke
    7
    ok sounds good to me i dont wanna spend silly money though i can get standard clutch and flywheel fitted for around 900 would it cost loads more to go for a performance item? Will the car still be driveable on a daily basis i have been offered company car so this is the point where i give up or go for silly power figures but judging by a forum im sure you guys will advise me to go down the obvious route......POWER :
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    i thought my clutch was slipping seems to be alright at the minute but the flywheel does need doing. Cant see any point in replacing both until the clutch is slipping whats the worst that could happen ? was gonna go with standard fitment i have a stage one remap which it has coped with for 22k on 66k at the moment
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Sep 2009
    Essex
    2,366
    i bought a solid flywheel and sachs clutch/pressure plate yesterday for 120... hugely discounted
    anyone know about the rear crank seal on the 20vt? are they all generic becuase im putting a new one of those in too.
