AH FabricationsVolks Autos
Results 1 to 20 of 20
    nath-w's Avatar
    Mar 2009
    134
    air filter question??
    Today while i was replacing my dipstick guide which i broke whilst doing my thermostat, i thought i would quickly check the air filter as i havnt owned the car long. Anyway it was filthy. I did think my car was a bit sluggish for a 1.8t, so i took it for a nip down the road with the airbox unclipped, and wow what a difference, cant believe how much more responsive my car was, and i could even here the turbo.
    Anyway now i want a new air filter, but not sure whether to get a panel filter for standard box or get a cone filter. Also if i got a cone filter what would i do with the sensor thats screwed to the side of the airbox? Found this a bit strange as i used to own a 2001 s3 which didnt have this sensor on the airbox?
    S3 Johnny's Avatar
    The grass isn't always greener
    Sep 2009
    Somerset
    211
    Green Cotton Panel Filter All The Way Mate
    S3 03, Ming Blue, Genuine RSTT's, BOSE, Sunroof, Factory Lowered, Centre Armrest, Greencotton filter, REVO, Forge 007p (Yellow Spring), Black DiamondDrilled and Groved Front Disks and Pads, Custom FMIC withYellow pipes SOLD
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    or jetex cone....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by nath-w View Post
    ...Also if i got a cone filter what would i do with the sensor thats screwed to the side of the airbox? Found this a bit strange as i used to own a 2001 s3 which didnt have this sensor on the airbox?
    ...its an ignition amplifier... later coil packs have all this built in to them (which makes them even more prone to failure)... you just need to re-mount it somewhere... I think its mounted to a heatsink? can't remember off hand... couple of others (Alpine, A3Tom) have done similar I think...
    <tuffty/>
    nath-w's Avatar
    Mar 2009
    134
    So does it not matter where I remount it the engine bay, or does it need to be near or inside some type of cold air feed?
    Sep 2009
    Essex
    2,366
    or just get another paper one!
    Jun 2003
    World of my own
    9,813
    Stock paper one has proved time and again to be the best.
    Alex Turner
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    I just use oem changed every 10k ish
    red to red black to black blue to bits
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    this is what you want
    Now to many mods to list! Lots of power, torque and Leather!
    Sep 2009
    Essex
    2,366
    Quote Originally Posted by fingermouse View Post
    and it costs pennies and it filters PROEPRLY
    S3 D2HTY's Avatar
    Apr 2010
    121
    What induction kit is that?
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Screw the Ignition Amp to the plastic wiring casing that runs down behind the air box with small self tappers. Thats what I did - worked a treat.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by S3 D2HTY View Post
    its one i developed for the 1.8T lump. has direct cold feed running to the filter and is in a nice cool place. Heat shield`d pipe going to the maf and fannys ya uncle. cold air and lots of it. Proven figures i posted on here works a treat. sounds nice too
    S3 D2HTY's Avatar
    Apr 2010
    121
    What parts did you use?
    Where did you source them from?
    Thinking doing the same on my S3 . . .
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    local sources, got cold air feed from a place in essex via ebay, custom made plates made either buy myself or by my pals at the steel works. you can get simalar bits off the bay but i found them to be quite sh1t quality. Filters i get from a local tuning shop/factory. there Simota filters.
    S3 D2HTY's Avatar
    Apr 2010
    121
    Cool cheers for the info
    nath-w's Avatar
    Mar 2009
    134
    Did you have to move the battey as my battery is close up to the wing, so theres no room to put a cone filter beside it?
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    yep i moved the battery. only by about 3" tho
    Mar 2010
    Porthcawl,Wales,UK
    63
    what did you do about the oil breather pipe?
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    mine dont have a oil breather.. but for those that do just pop a mini filter on it. shimples!
