JMB RetrofitsBadger5
Results 1 to 14 of 14
    S3 Johnny's Avatar
    The grass isn't always greener
    Sep 2009
    Somerset
    230
    Question for anyone with an FMIC and a Remap??
    Hi Guys
    I'm getting a FMIC fitted very some and i've got a remap aswel, i was just wondering if i needed to get it remapped again or not?
    Thanks for your time
    Johnny
    S3 03, Ming Blue, Genuine RSTT's, BOSE, Sunroof, Factory Lowered, Centre Armrest, Greencotton filter, REVO, Forge 007p (Yellow Spring), Black DiamondDrilled and Groved Front Disks and Pads, Custom FMIC withYellow pipes SOLD
    Aug 2009
    Gosport, Hants
    367
    As far as I know, you don't need a remap after fitting a FMIC, as it'll just allow your engine to make the remap power for longer, whereas before you would lose power when things heated up. However, you will need a remap to release the full potential of the engine now it has a better cooling arrangement, i.e you'll be able to dial in more ignition advance. Someone please correct me if I'm wrong.
    2003 Dolphin Grey S3, with a few mods....
    S3 Johnny's Avatar
    Sep 2009
    Somerset
    230
    I'm sure someone said that you have to get your map tweeked after you get a FMIC to make it run right
    S3BAM's Avatar
    Dec 2009
    Quedgeley Glos
    408
    Always worth getting the map tweaked as you will get much better power higher revs with Fmic...
    What other mods have u got...
    S3 Johnny's Avatar
    Sep 2009
    Somerset
    230
    Quote Originally Posted by S3BAM View Post
    Just the DV and Panel Filter at the mo, do you know how much it should cost for a tweak mate?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    You don't need to change anything, fitting a FMIC will make your current power output available more of the time.... the SMICs heatsoak very quickly and a couple of spirited acceleration runs will cause them to heat up and this in turn highers the air intake temps casing the ECU to pull timing and enrichen fuel mixture to keep things cool inthe engine... this of course kills performance... FMIC will keep the AIT's lower, recover much more quickly from heating up from the hot intake air and means the ECU will not be pulling timing anywhere near as much and you will sustain power...
    After fitting a FMIC and a few other bits you could go stage 2 which just means that you should be able to run a bit more timing advance and boost as the FMIC/DP etc help keep the combustion process running cooler thus producing more power...
    <tuffty/>
    S3 Johnny's Avatar
    Sep 2009
    Somerset
    230
    What else is need for a stage 2 tuffty? and how much do they set you back?
    Thanks mate
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Quote Originally Posted by S3 Johnny View Post
    Thanks mate
    Stage 2 prerequisites are typically FMIC, 3" DP with a sports CAT, air filter of some description (which you have)... optional are things such as Forge DV (which you have), silicon hoses (mainly a TIP) and an aftermarket exhaust but most important things are the bits that aid air flow and help keep AIT's and EGT's low so that you can run a bit more boost and timing which is pretty much what a stage 2 is...
    Cost wise as you already have a Revo map I think its 50 to go stage 2 but obviously the other bits add to the overall cost... the thing to remember though is that a stage 2 doesn't give you much more power over a stage 1 but in conjunction with the upgrades you will have fitted you will have most of the power most of the time rather than all of the power once then some of it for the rest... heat is an engines nemesis and anything that keeps AIT's and EGT's low will give you more sustained power..
    <tuffty/>
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    S3 Johnny's Avatar
    Sep 2009
    Somerset
    230
    <tuffty/> = TOP MAN
    105
    Hi mate just wondering which fmic your going for as im planning too get one soon?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Quote Originally Posted by s3 kam View Post
    http://www.audi-sport.net/vb/showthr...image-heavy%29
    <tuffty/>
    S3 Johnny's Avatar
    Sep 2009
    Somerset
    230
    I'm getting a custom one made all in for 450. Tuffty thread is good too.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    im going to get one of the AH fabrications FMICs and then get it mapped again so i can run higher boost...all i have is a silicone TIP and Forge DV......
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
