Badger5Chris Nott
    feville's Avatar
    Frank
    63
    A3 Driver's window regulator cable snapped....HELP!
    Has anyone had much experience with regard to changing either the cable or the whole regulator assembly?
    I have just had a quick browse on fleaBay and seen the repair kit's for Ł25inc postage.
    Any help would be much appriciated!
    R-Tech remap - Forge 007p - Forge carbonio - Janspeed catback - N75h - Coilovers - TT comp rims - Powerflex bushes - EBC stoppers
    martin g's Avatar
    [censored]
    somerset
    154
    Yes done this recently, its a lot easier than it looks, toughest parts is positioning the door sub frame correctly on rebuild.
    You will need a pop rivet gun of your changing the lot fella, along with decent sized star drive sockets and some light grease. The link below should help you get through it.
    http://www.piglet-net.net/tech/cars/a3-window.html
    feville's Avatar
    Frank
    63
    Cheers bud, diud you replace the whole mech or just the cable? i just ordered the whole lot, thought it easier and couldnt find a uk seller for the cables...
    martin g's Avatar
    [censored]
    somerset
    154
    I just replaced the runners and the motor myself but the rest seems straight forward enough. And your welcome though I shouldn't be here really.
