Volks AutosAH Fabrications
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Abs + Esp light on (random times)
    Hi all.
    My asb and esp light have started coming on together.
    Just gave a quick vagcom.
    The code said something about hydraullic modulator?? I had the battery cover off today, to put a surge protector on... Do you think i could have disturbed "THE" fuse??
    I just had a quick peek and couldnt see anything amiss.
    cheers
    Callum
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Have you checked the fault code against the ross.tech vag.com wiki ? (there'e a link to it somewhere on here)
    might give you a clearer indication of the problem
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Yeah the code is 01276 - hydraullic modulator intermittant fault
    After some searching, i found the 3x 30amp fuses (ontop of the battery) can be related to the fault.
    Popped them out for a visual check, and they all have marks.. like they have been arcing out??.
    Anyhow i rotated them all and swapped them round. so ill see if it cures the fault.
    Hopefully i wont have to fork out for a new pump or controll unit
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Give them a clean, including the connectors. Mine abs fault went after this
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    Have a look at the multi plug near the back of the battery that links to the fuses as mine did the same, this plug controls the fans to so keep a eye on the temp
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
