    Apr 2010
    7
    Front and rear washer not working, but headlight washers are fine!
    My S3's front and rear washers ain't working. Headlight washers work fine though!
    Checked that the fuses are fine, and couldn't hear the pump running. Put a voltmeter to the terminals going into the pump, got someone to activate the wiper/washer but didn't get a reading. Where should I look next? Any pointers appreciated!
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,078
    If the electrics are fine, I would check the pipes for blockages or for connection to the bottle/pump.
    Apr 2010
    7
    well, the thing is the electrics don't seem to be fine for the front and rear washer pump as i don't get a voltage reading even when the wash/wiper stalk is activated. but the fuses are fine.
    am i right to assume the other pump is for the headlight washer pump?
    Apr 2010
    7
    hi, this is still stumping me. any suggestions guys? tks.
    Ross_S4
    Aug 2009
    Dundee
    718
    headlight washer pump is on the front of the reservoir next to the headlight rear cover if that is any help.
    maybe your stalk switch is knackered?
Tags for this Thread
