EM TuningChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 57
    Aug 2008
    114
    Clay then t-cut?
    Lookin at givin me car a good clean before summer, I've got a clay kit and also want to get rid of light swirls and scratches.
    Would I clay it then t-cut it or is there any other products you would reccomend?
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    erm id personally stay clear of Tcut, you'll probably create more swirls using it!! sounds like you need a proper machine polish to me
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,078
    AHHHHH THE T WORD!
    Don't use T-Cut.
    Menzerna 203s on Audi paint if you want to rid yourself of swirls by hand (difficult). As Timotey says, a good machine polish is the only real method of getting rid of swirls.
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    I've just bought myself a DA to rid my car of the swirls, really can' be bothered using it though ! lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Throw the T Cut in the bin.
    As has been said there are better products that wont ruin your paint. If you're doing it by hand then have a look at Auto Glym Super Resin Polish. It has fillers in it and can give some great results if the paints not too bad. Anything more than very mild defects though will need a maching (rotary or DA) polish as you wont get them out of hard Audi paint by hand.
    I use either a rotary but lately tried a DA hand sander with speed adjust on it...its great for minor work and easier to handle than the rotarty (rotary can kill paint in the wrong hands).
    Have a look at the guides in the detailing section,....full of info.
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    Quote Originally Posted by JD09 View Post
    AHHHHH THE T WORD!
    Don't use T-Cut.
    I'll add to the advise already given. Both the above products are good, however VAG paints are renowned for their hard clear coat application. My advise would be to post up some pictures of the affected car and we can advise in more depth. Menzerna PO203S is a polish, you probably wont get the finish you require with this product alone but a mixture of S100 and PO203S maybe even PO106FA would give a nice clean finish. It really does need to be used with a machine to achieve great results on a whole car, rather than individual panels. Say your hood is worse than the rest of the car for example!!
    So assuming you wish to use a machine:
    The general rule would be on fairly bad paintwork with moderate swirling would be to use Menzerna PO85RD 3.02 (intensive polish) to start with. If you do not get the required result then move to Menzerna S100 (power gloss) or a mixture of both depending on the cars state. On my last 3 Audi Details I was forced to use S100 as the clear coat was that hard. The main objective is to remove as little clear coat as possible, so start light and work your way through the products until you are satisfied with the results of the "first" pass of the polisher. You would refine the finish per panel then using something like PO106FA and could use a mixture of two Menzerna products to get a really sharp and clear paint correction with minimal effort required, just takes time and patience.
    You'd need to seal the paint finish then using FinishKare 1000p or Collinite (both cheap and very good products). You could then wax the car if you required, I always do, the product would depend on the colour of the car!
    If however you are only doing this by hand then you could use Autoglym SRP (super resin polish) followed by a wax, Autoglym do a High Definition wax which is "ok"! This would not give you any real correction it would "hide" some imperfections which are visible and mask the swirls slightly at best.
    It depends on how bad the car is to start with and what you want to achieve with it. A perfect finish would require machining, but an "ok" finish can be achieved by hand methods only. Get some pictures up and tell us what you wish to achieve.
    Hope that helps a little!
    G
    Aug 2008
    114
    cheers chaps! will try to get some pics up.
    whats a DA polisher as people mention? would i be able to hire a machine as this may be cheaper? cheers
    JD09's Avatar
    Dec 2009
    3,078
    I doubt you would be able to hire it, plus you won't be up on it's use.
    For the fuss and bother, I would see if there is a local detailer that can take the car back to pristine condition for you to then keep on top of.
    JD09's Avatar
    Dec 2009
    3,078
    Oh, by the way, DA stands for Dual Action, it basically mimics the movement of your hand but at several hundred times the rate.
    Aug 2008
    114
    hopefully you can see what i mean, thisis onthe bonnet which is worst place.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,637
    Visit s3 Hoggy's Instagram Channel
    Blimey you'll struggle to touch that by hand!
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    JD09's Avatar
    Dec 2009
    3,078
    Oooft.
    Machine Polishing is going to be your only option;
    That was achieved through just a Dual Action polisher, with Lime Prime and a 3M polishing pad.
    Aug 2008
    114
    what did you use on that clio looks good? how much you recon a detailing place would charge? what does it need buff or polish? cheers
    JD09's Avatar
    Dec 2009
    3,078
    Where are you based lad? If I know your location, I can recommend.
    I have added the process above chap.
    I wouldn't like to quote for others, as I only do it as a hobby at the weekends (if/when I have one free). Happy to PM you, but let's work on suitable locations first.
    Aug 2008
    114
    im located just inside north wales near chester, is i was to buy a machine what price would i be lookingat?
    cheers for your help mate
    JD09's Avatar
    Dec 2009
    3,078
    No worries. Near me then, ish.
    Price on machines is around the 1-200 mark. Coupled with pads, polishes, etc etc.
    However, the thing that all detailers, myself included, will bang on about is the experience. Yes, DAs are safe, but guarantee you will not get 100% out of the machine on your first go. That's nothing against you or any other person starting out, but it isn't pick up and play.
    Of course I will push for you to pay/A N Other for a detail, but I can assure you from talking to a lot of newbies, it is much more worth getting the car in a fit state with a one off cost, and then me teaching you how to stay on top of it.
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    LOL...get in there son!
    I'm the same as JD - Amateur Detailer during weekends when I have the time, got a fair few cars booked in over the coming months.
    My last detail was an RS4, one which was as bad as they come. See the link below for a write up and pictures of the difference. This is what can be achieved with the right products and a little patience!
    http://www.audi-sport.net/vb/showthr....G-vs-Audi-RS4
    I really hope you get it sorted (I can't see pictures in work, but i'm sure judding by comments that its pretty bad), remember though everything is possible given time & money!
    Keep us updated, it's nice to see other cars that have been restored to their former glory!
    G
    JD09's Avatar
    Dec 2009
    3,078
    I saw your username and thought "here he is, bullying in on my thread". Ha.
    But as above even the worst paint can be greatly improved. I will now show off my work
    ASton Martin DB7 Vantage Volante - washed with grit for the last 8 years;
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    ROFL.....
    I can't see pictures!
    G
    JD09's Avatar
    Dec 2009
    3,078
    Porsche Carerra 2 coming up this weekend G lad Nice blue un
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    Hehe I've a Lamborghini Murcielago booked in for July. But hey it's not a competition! :P
    Stop hijacking the poor lads thread with your detailing jobs will ya! LOL.
    G
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,637
    JD and Mr G ive got a veyron booked in for next wednesday so trumped you both! cameras broke so cant take pics sorry!
    2002 S3 REVO
    JD09's Avatar
    Dec 2009
    3,078
    W'ever Trevor!
    Any, back to the topic, I would suggest looking into a detailer. Jimmeh is more likely to be able to book you in than I am, but still worth a chat for June as the other half is away, meaning more time!
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    ROFL Hoggy.
    Yes back on topic tut tut. Jimmeh is a top class professional, well worth getting in touch.
    G
    Aug 2008
    114
    Where is jimmeh from?
    Just been to a local company attention 2 detail there called an they said 120 for full car machine polishd then dodo juice products used on it.
    Would you guys say this is good?
  28. #27
    JD09's Avatar
    Dec 2009
    3,078
    I'd say that was cheaper than me . . . hmmmmm. Sounds too cheap to me.
    Jimmeh is midlands based.
  29. #28
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    Not sure about where Jimmeh is from, why don't you PM him to find out?
    120 for a machine polish? Does that include paint correction or not? Anyone can machine polish a car but achieving correction (de-swirling etc) is something entirely different.
    It seems cheap for a full correction detail.
    G
  30. #29
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Can any of you detailers please move "daaan saaath" (down south) so that I can get my car done
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  31. #30
    JD09's Avatar
    Dec 2009
    3,078
    Keep getting asked for Southern Detailers . . . I have nothing
  32. #31
    Westy's Avatar
    Dec 2008
    17,156
    These guys are very good and just around the corner to me but they are very pricey:
    http://www.autofinesse.co.uk/
    S3 Build Thread
  33. #32
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    45 per hour is steep!
    G
  34. #33
    JD09's Avatar
    Dec 2009
    3,078
    Bloody steep based on the fact that most cars I book in take two days. Put it this way, Clio's took 10 hours over one day for paint correction alone (all that most wanted). That was 125.
  35. #34
    Westy's Avatar
    Dec 2008
    17,156
    Not only is 45 an hour steep but that's just the paint correction. My interior needs a bit of TLC too
    S3 Build Thread
  36. #35
    JD09's Avatar
    Dec 2009
    3,078
    LOL! Just worked that out, for example for the price/time quoted for this weekend's Carerra; 900. Joke.
  37. #36
    Westy's Avatar
    Dec 2008
    17,156
    Yep It would be cheaper to get a full respray!
    S3 Build Thread
  38. #37
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    So do you guys know of any Detailers north west area...? I spoke to a guy who runs a valeting centre near me who seemed to know his onions but only uses auto smart products.. are they any good or dog sh*%t
  39. #38
    JD09's Avatar
    Dec 2009
    3,078
    The Clio above was based in Blackburn, I'm NW (south Manchester). Happy to quote Damo.
  40. #39
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    It's not in bad shape just a bit of swirl on most panels and the odd little scratch here and there. She just needs a proper good going over.
    Had conv with jimmeh 'After seeing that Black Avant he did recently' Mint Job, but he's a bit of a distance really.. So yeh Nice one man fire away, what yr rates?? (Do you need to see pic's)
  41. #40
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    I think Jimmeh is Nottingham based, but its worth going to him or him coming to you, if you want top results.
    Seen alot of his work over the time and I have to say, it is of a VERY high standard.
