Monster MotorsportVolks Autos
    Jul 2009
    520
    Changing top mount bushes/bearings
    I have done a bit of research into changing the top mounts, only really found a guide on a mkiv R32.
    My questions is... as I have coilovers, do i still need to compress the springs to allow enough slack to remove the top mounts? ro could i just wind the coilies right down?
    Any other guides out there?
    Liam
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Depends how much preload you have, i would bet if you wound them all the way down you would be ok, as i have done some on springs only and can fit/change the top mount by body weight alone
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    You usually have to take the strut off, even with coilies mate.
    The Damper tube is usually a similar length to the original, however with coilies you shouldnt need spring compressors - which is a bonus.
    Jul 2009
    520
    so i can just wind the coilovers right down and that should take the pressure off?
    Also, been looking up techniques on removing the top nut with the allen key fitting inside. some people are using 21mm spark plug sockets, however, i have just tryed testing a 21mm spark plug on the nut and it dosnt fit, however a 22mm normal socket does. can anybody shed any light on this? is it supposed to be 21mm?
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    i got a socket and ground 2 flats so a spanner would fit it then used allen key through the middle, sorry don`t remember size but 22mm sounds about right
    red to red black to black blue to bits
