JMB RetrofitsSky Insurance
Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
  1. #41
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by zeeeebo View Post
    mines an a3 but yer i will be changin the fuel relay and have a drive see what happens then also put the earth on! would like to find out what the 4 earths are so i can unplug each one while car is on and try and make it die and throw the same fault codes up so then i canrule them out
    To be honest dude, I can't remember exactly where those earth points come from, or what they are for. But I believe that they are the main engine loom earth points.
    As Bill said,
    follow the larger earth from the battery to the chassis and to the bell housing clamp bolt..
    possible disconnection there
    Homer Simpson
  3. #42
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    anyone know the part numbee for fuel relay
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
  4. #43
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I tried to look on VAG CAT mate, but I can't get on to the EPC for some reason....
    Phone Audi is your best bet.
    Homer Simpson
  5. #44
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    are these the modules? if so which ones the fuel relay??
    the 4 wires under the battery tray
    the earth wire from battery to engine looks ok
    -AUDI A3 1.8T-
  6. #45
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    The oil on the plugs will be from a leaking cam cover gasket. It pools up around the plug a little so when you unscrew them the oil runs onto the plug giving the impression there is an internal engine problem.
    Fuel pump relay should be the 4th slot from the left which would be the one with "167" written on it. Rest your finger on it as you prime the pump. You'll feel it click inside. Also there will be a red/yellow wire connected to it.
  7. #46
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    just a quick update, took apart the battery tray to get to the 4 earths again gave them a very good clean! i also ran the car and unplugged each earth in time but couldnt get engine to cut out. spent ages waggling around differnt wires checking for loose conections. the car hasnt cut out now for 200ish miles so perhaps it was the 4 connectors but im still unsure, i will be replacing the fuel relay just for the sake of it as im trying to sell my car at the mo and dont want to sell it with any problems!!!
    -AUDI A3 1.8T-
  8. #47
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    p.s if it does cut out before the fuel relay is put in then people are still in the runnings for the tenner will keep you all posted as someone might find this thread very use full in years to come as i know how many hours i have spend searching many forums trying to find the answer!
    -AUDI A3 1.8T-
  9. #48
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    ok found something interesting on my lunch break. if i clear all error codes and unplug the fuel pump relay and try to start the car, the exact same 6 error codes come up! aka sort to earths on all the injectors etc
    -AUDI A3 1.8T-
  10. #49
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    cant be bothered to check all the posts but has anyone mentioned the crank sensor?
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - ÂŁ2500 Mods Inc
  11. #50
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by DaveA3 View Post
    Would throw a fault code for the sensor as well as cutting out next to all the time. I had a crank sensor pack up, and it was not a happy bunny.
    Good shout though.
    Homer Simpson
  12. #51
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Good test - get a replacement for testing further.
    Also check the pins on the replay and the female side as well for corrosion.
    Homer Simpson
  13. #52
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    yer i thought the crank sensor first of all but as welly said it would throw a fault code
    -AUDI A3 1.8T-
  14. #53
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    my dads didnt throw a code on his a4. it would be fine for weeks then starts playing up again. it got worse and worse. Until my cousins uncle (indy mech) changed the sensor then it was cool. sounds similar just wonder if ur digging too deep mate. but im no mechanic just a guy who reads forums alot lol
    could get one from euro car parts or something n take it back if it dont make a diff. think u get a couple of weeks
  15. #54
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    That's a fair point mate, I guess the don't always throw codes, as is true with all sensors.
    However, the crank sensor dying intermittently wouldn't give the fault codes that are being given by the ECU.
    Homer Simpson
  16. #55
    Dec 2009
    20
    if it cats out randomly is more then likely the cranck or cam sensore it want cum up with anyfaults while running!shouldn t be to expensive to replace/
  17. #56
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by durk View Post
    Are you people actually reading the first page discussion, or Z's findings today? LOL.
    99% of the time the crank sensor or hall sensor will throw a fault code when failed.
    Homer Simpson
  18. #57
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    who git the tenner then?
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
  19. #58
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    Unsure if this is related, but had the same problem with a peugeot i owned.
    It also seemed as if it had ran out of petrol, and if i pumped the throttle it would back fire. When it first started it, if i unscrewed the petrol cap (sounds daft i know) it would run enough to get me home, leave it for an hour and car ran fine again.
    I found in the end it was the fuel pump, replaced it problem solved.
    It's better to burn up, than to fade away...
  20. #59
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    once i have replaced fuel relay i will drive 500miles if it doesntcut out the first person that mentioned the relay will get it
    -AUDI A3 1.8T-
  21. #60
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    p.s everyone will get a thanks for helping=)
    -AUDI A3 1.8T-
  22. #61
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    LOL, always happy to help out mate, the money isn't what makes me want to!
    Homer Simpson
  23. #62
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    yer half my mind wants to give it to you welly as this isnt the first time you have helped out!!! if ya ever need my help give us a shout!
    -AUDI A3 1.8T-
  24. #63
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I'm good matey, money is overrated! LOL.
    Homer Simpson
  25. #64
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    haha tell me about it i work in a bank haha!
    -AUDI A3 1.8T-
