Badger5AH Fabrications
Results 1 to 11 of 11
    stuck behind a tractor...
    Apr 2007
    Norn Iron
    17
    Unhappy help fixing driver electric window.....pics included...
    as the titles describes , my driver window has gone kaput !!!
    I have had the door card off and the motor is working fine but it appears to be the cable that runs into the white reel on behind the motor has snapped off and you can see (attached pictures)both the cable and wire below it.
    Anyone know how hard easy what is needed to get this back together and pref not removing the subframe of the door would be good lol !!
    cheers walder
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    This happened to me a few months back. Is yours an S3 or an A3, mines an S3 and I tried finding a new cable but no one seems to do them. If yours is an A3 then you can get a new cable on ebay for 15, for some reason they are a different size to the S3's which is really annoying for me. The only option if you have an S3 is to buy a new regulator which is about 70. Unfortunately you will have to remove the door subrame either way, but it's not as difficult as you may think. It's just a question of disconnecting the mirrror wiring plug and undoing 4 torx bolts. You may also want to remove the glass first.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Apr 2007
    Norn Iron
    17
    cheers lemon !!!
    its the 1.8t a3 sadly a few ponies off an S3 !! im flat out with work at the minute how long would it take to get the subframe off and new cable ran etc say someone that has no experience in doing this, this way gives me the max no. of hours to get it done..
    Apr 2007
    Norn Iron
    17
    also does anyone know what steps are involved in replacing the cable?
    Apr 2007
    Norn Iron
    17
    i have the cable orderd any one give me a rough guide as how to fit the new cable....???
    cheers
    Apr 2007
    Norn Iron
    17
    anyone?????????????????
    feville's Avatar
    Frank
    63
    Hi there, i was just wondering where you got your cable from as my car has just done the exact same thing!...
    R-Tech remap - Forge 007p - Forge carbonio - Janspeed catback - N75h - Coilovers - TT comp rims - Powerflex bushes - EBC stoppers
    martin g's Avatar
    [censored]
    somerset
    154
    Apr 2007
    Norn Iron
    17
    got it off ebay just search a3 electric window cable seemed to do the trick for me
    @martin g cheers buddy !!! but just had a quick scan as i am at work ! but this guide will let me re connect a new window cable and not go thru the process of replacing the regulator ? but cheers again
    martin g's Avatar
    [censored]
    somerset
    154
    not sure you can easily bud, it seems the winder itself is self contained but i could be wrong, for me it would be easiest to just replace the lot tbh
    Sep 2009
    Essex
    2,366
    go to audi or vw. ask for a new regulator kit. about 60.
    apply your old motor to the new regulator. done
