EM TuningJMB Retrofits
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Finally my ABS Light problem is sorted
    Almost a year i had a problem with this ABS light kept comin on and the warning beeps kept beeping. Most people said sensors went, or it could be the pump
    i cheked all this but never sorted it
    Connected it 2 vag com, yesterday and came up with error code, (error thread) the code didnt help much
    So this morning i disconnected all my amps etc, and charged the battery, problem was still there so i gave up, On top of the battery there is a little fuse holder which holds 3 30amp fuses, i only had 1 in, so jus 4 an idea i moved the fuse to the middle one, my BLEEPS WENT and my abs light went, drove it, then the abs light came on, so got rid of the bleeps but lght was stil there, i then put 3 30 amps fuses in all 3
    This sorted the hole problem, so ne 1 with ABS problems chek this fuses [img]/ubbthreads/images/graemlins/smile.gif[/img]
    and my MOT PASSED [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    [img]/ubbthreads/images/graemlins/dancing.gif[/img] [img]/ubbthreads/images/graemlins/****_you.gif[/img] [img]/ubbthreads/images/graemlins/1luvu.gif[/img] [img]/ubbthreads/images/graemlins/goofy.gif[/img] [img]/ubbthreads/images/graemlins/hug.gif[/img]
    May 2004
    Surrey
    310
    Re: Finally my ABS Light problem is sorted
    nice one.
    Bet your well happy. Even more so that you didnt have to take it audi.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Bloomin ekk as simple as that!
    Good work that man. I'll remember that one.
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    that is a common problem you may find the plastic plate to have melted underneath, it is worth checking as i have done numerous numbers of these causing either abs or airbag faults!
