Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By MickM
Thread: Turbo Intake Pipe Fitting
    Feb 2009
    69
    Has anyone got a decent guide for fitting a TIP?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    It's pretty straight forward mate to be fair.
    Remove pipe from MAF, remove N75, remove oil breather, remove diverter valve.
    Undo jubilee clip that secures it to the turbo. Give the original TIP an good pull to get it off. Spray a bit of WD40 around the inside of the TIP end going on to the turbo, slide on, jubilee clip up, refit everything.
    Done.
    Homer Simpson
    Feb 2009
    69
    Ok, cheers bud! Am sure i'll be back askign for help once if Tit'sd it up!
    Got a weekend of fitting Coilovers, TIP, DV, Air Filter and hopefully new Brakes and hopefully organise a re-map all in time for the Le mans trip!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    Steady Welly me ol' mucker... Mick, is your car an S3 or an A3 as they are different... S3 is as simple as Welly has suggested although maybe not the WD40 on the turbo end of the TIP in my experience... hairspray works better as it will evaporate without leaving oily residue which could cause the TIP to vibrate off the end of the turbo...
    If you have an A3 then good luck! LOL... its a bit trickier on an A3, A3Tom has done an install guide somewhere on here for the A3
    <tuffty/>
    Feb 2009
    69
    Bugger, is an A3! will try and find Tom's guide
    Looks like its going to be a long weekend!
    Feb 2009
    69
    Just found a link to Tom's guide: http://www.audi-sport.net/vb/a3-s3-f...w-fit-tip.html
    Thanks for the heads up Tuffy
    fanta likes this.
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    nice one for finding that Mickm.
    nice write up TOM.. are they M short speakers i see in the background of your 1st pic?? i to have those
    Now to many mods to list! Lots of power, torque and Leather!
    Feb 2009
    69
    Sorry Tom, forgot to say Thanks!
    .S Look like MS Alumni (SP??) to me, i have the same set!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Hey? My A3 was easy enough dude, I followed exactly that process..... LOL. I I like WD40 so there! :-P
    EDIT: Oh, the metal intake elbow!! I forgot about that....
    Homer Simpson
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    only tip i would give is use a ratchet to undo the jubilees, some have tried with a screwdriver which will make your life very miserable as you have to undo most jubillees by feel
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    <tuffty/>
    Feb 2009
    69
    Guys, to save a new thread have i missed anything obvious:
    Looking to get around the 200BHP Mark. AGU K03 Turbo.
    TIP
    Uprated Air Filter - worth running a better cold air feed from the bumper?
    Forge 007
    Miltek Cat Back
    Custom Map
    Also shortly be ordering Jamex Coilovers and some decent brakes. Sadly can't afford to go the K03S route as well coilovers/brakes and daren't put any more power through the shoddy Standard Brakes/Suspension.
    Coming from a Slammed Clio with Brembo's it feels like a boat standard!
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    The speakers are Mordaunt Shorts yep
    as for getting about 200bhp out of your A3, the spec you're going for is pretty much what I have so you'll be knocking on the door of 200bhp as long as the cars pretty healthy. You'll really struggle to get over 200bhp from a KO3 though as they just run out of puff. Saying that the KO3 AGU is nice to drive with a stage one map on it so you'll be well happy.
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Swornd's Avatar
    Mar 2009
    50
    Quote Originally Posted by MickM View Post
    Just found a link to Tom's guide: How To Fit a TIP
    Does anyone have a copy of this anywhere as I just get a error when I follow this link. Cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    I think a recent forum 'upgrade' is to blame here... this means that all previously posted links to threads/posts within the forums could well be buggered...
    URL rewriting at its worst
    Using the power of my IT background and swapping bits of the actual URL about I came up with this..
    Code:
    Before...
    http://www.audi-sport.net/vb/showthread.php?75046-How-To-Fit-a-TIP
    After...
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/75046-how-fit-tip.html
    <tuffty/>
    Swornd's Avatar
    Mar 2009
    50
    Ah cheers Tuffty, thought it would be strange that it would of been deleted. Hm I would imagine it wouldn't be too hard to write a script to fix all those links, could get annoying if all of them are like that!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Homer Simpson
