EM TuningMonster Motorsport
Results 1 to 23 of 23
    Nov 2003
    Central Scotland
    253
    Large Port A3T Head on an S3
    I have read on here a few times about the AGU head off the 150 1.8T having a much better flowing head due to the larger ports. Would this not be an excellent mod for S3 owners??
    Question is, why didn't they put this on in the first place?? I'm confused!
    Stevie
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: Large Port A3T Head on an S3
    [ QUOTE ]
    Stevie
    [/ QUOTE ]
    S3's have VVT.. which uses a differnt head than the AGU. hence the change! You can fit the head to the car, but would require a remap to 'code' out the VVT bit... The upside is that you an run less boost for the same power! my 1.2 bar compared to wilkos 1.5bar on the IHI and the power outputs are very close indeed!
    Rich
    Feb 2004
    UK
    1,320
    do all s3's have vvt?
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    I could be wrong there...
    PaulS3's Avatar
    UK
    988
    im not sure,
    i was led to believe early ones were oil pressure driven and mechanical.
    but 225's were electrical driven solenoid thats on the RHS of engine as you look from the bonnet..
    something to do with the torque delivery i was told. and the torque did change slightly between the 210/225 lumps
    Oct 2003
    South Wales
    2,942
    [ QUOTE ]
    jojo said:
    [ QUOTE ]
    DickyS3 said:
    Later S3's were VVT, earlier ones wern't.
    Rich.
    [/ QUOTE ]
    Rich, I'm sure Paul is right in that all S3's have VVT, but were mechanical operated in 210 versions, and changed to solenoid for 225 versions... I remember reading a post on it sometime ago...
    [/ QUOTE ]
    I thought early S3's (APY) didn't have VVT?
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    When I was enquiring about the Jabbasport kit for my S3 they asked for the year of manufacture to check it had vvt so that would suggest that earlier S3s did not have it
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    104
    I'm looking into fitting an large port non VVT head onto my VVT golf. Should have a brand new large port head in my hands end of the month.
    The plan is to fit the cams and vvt gear from my head to the large port one. The VVT cams have higher lift and longer duration (i've been told), so it should be the best setup.
    To the original question though. No 210/225 engines have had a large port head. The problems you will have is that all the cars that have (golf, a3) have the intake manifold handed the other way, and this has larger runners to match the ports.
    One option is to buy a dahlback manifold as they will supply them in any combination of handing and port size.
    Rich. Fancy a trip to JBS on sunday. 4 IHI cars there already, and I'm sure 1 more would be welcome. It'd be interesting for comparisons sake, as I reckon my cars dragging 100kg's more than yours around. 2 extras doors, sunroof, seat airbags, climate, third centre belt with seat strengthening, and all that other crap that I don't need.
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    John,
    Will see what im upto on sunday...Might have other arrangements already [img]/ubbthreads/images/graemlins/frown.gif[/img] If not i will be there! As for the 100kgs, whats the dry weight of your car? Mine is 1246kg. has seat side airbags and all the other bits you mention other than the 2 doors and sun roof... On the AmD day i was also carrying my weekends luggage, BIG sub box .etc.
    On the Dahlback front, I will have mor info for everyone hopefully by the end of the week! Speaking to Mr Dahlback himself last on this week!
    Rich
    104
    Cool. Hope to see you sunday.
    Had mine weighed at over 1300kg's without me (fat bloke)
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    Seen this on VW Vortex its a spreadsheet of engine codes and some info on each, it refers also to the APY code having no VVT
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    Here's the link to the thread HTC but it only contains the same jpg the spreadsheet hasn't been posted yet
    http://forums.vwvortex.com/zerothread?id=1661754
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Okay, thanks anyway.
    nervus's Avatar
    Apr 2004
    1,116
    That IHI badge you have made looks good! It will have the saxo boys scratching their heads!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Very true, but the Subaru guys should get it.
    nervus's Avatar
    Apr 2004
    1,116
    yeah [img]/ubbthreads/images/graemlins/cool.gif[/img]
    104
    The subaru guys don't get to see it for long enough to read it. Keeps the 911 guys guessing though
    nervus's Avatar
    Apr 2004
    1,116
    not this 1, ill stay well clear if i see you to save my [img]/ubbthreads/images/graemlins/blush.gif[/img]
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    Certainly does! Was having some fun on the A40 with a 996 C4S... he over took the car in front as did i and we kept going... Found myself having to ease off! At the next set of traffic lights i saw him moving his rear view mirror to see what it was [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Feb 2004
    UK
    1,320
    just to add that the 7/1999 brochure for the s3 quote the engine as having variable valve timing,so i guess they all have it.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,845
    According to the list that Andy bS3 supplied S3's built between 11/98-08/00(APY) are non VVT, built between 09/00-04/02(AMK) is left blank?? and built between 08/01-05/02(BAM) is definitely VVT 225 bhp and has a forged crank shaft... doesn't really make sense [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Oct 2003
    South Wales
    2,942
    Does anyone know for sure? [img]/ubbthreads/images/graemlins/confused.gif[/img]
