Monster MotorsportChris Nott
    Apr 2010
    25
    how to program key??
    how do i program my key either using vagcom or another way, the problem is i only have 1 key, cheers dale.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,626
    You'll need two keys.
    1) Open the driver door, turn the ignition switch to on, but do not start the car.
    2) Close and lock the driver door with the other key (this should be the proper key and not just the valet key - I used the valet key first and wondered why the programming didn't work).
    3) Hold down both buttons on the fob for about 5 seconds. The lights should flash and the alarm horn should honk.
    4) Open the door, remove the key from the ignition. Close and lock the door with the key
    Apr 2010
    25
    i only got 1 key when i bought the car... is there any way of doing it on vag com? if not ill just get another key cut. cheers
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,626
    not that I'm aware,the immobiliser is bulletproof and has to be synchronised with the other key in the ignition.
    S3BAM's Avatar
    Dec 2009
    Quedgeley Glos
    408
    Where are you based spencerdale..???
    Ive got a guy near me who does keys "verns autoparts" in Tredworth Gloucester Really spot on Genuine guy.. charges 50
    Just make sure you get a unlocked key if u buy second hand off somewher like Ebay...(i think they can unlock but costs more)
