Badger5JMB Retrofits
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    498
    cam belt, timing belt ?
    Right i had a look under my car the other day while it was up on the ramps i noticed that the belt located on the passenger side of the engine looks brittle, am i right in saying this is the timing belt as im sure the cams are run by a chain on the other side of the block.
    is this the belt that causes major holes in your pocked when they snap?
    and any idea of a price to have a new one fitted?
    cheers in advance .
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    ermm... belt on the passenger side???
    <tuffty/>
    Cawsey
    Dec 2009
    Valencia, Spain
    498
    hahah sorry i ment drivers side my mistake
    Ross_S4
    Aug 2009
    Dundee
    718
    The cam / timing belt is on the drivers side pal. Not sure if it is even visible from below without removing covers.
    The auxiliary belt has grooves runing along its length. Look at the engine from above, the timing belt is under the black plastic cover on the end of the engine block. The auxiliary belt (alternator / power steering pump / aircon if applicable) is visible by looking to the left of your intake manifold where you will see the belt on your alternator pulley.
    You are half right though, one camshaft is driven by your toothed (timing) belt, this shaft then drives the other camshaft via a chain at the opposite end.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    lol... if its visible then its the serpentine accessory belt... grooved belt?
    Try this....
    http://www.audizine.com/forum/showth...AL-amp-INSTALL
    Pretty sure the 18mm spanner they suggest to use is a little too big, seem to remember it being a 15mm or 16mm
    Belts are around 10 to 15 quid IIRC
    <tuffty/>
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    15 mm dude. Deffo a 15.
    Homer Simpson
