EM TuningMonster Motorsport
Results 1 to 16 of 16
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    Remove SERVICE warning?
    As the title says, how do you remove the service light on the cluster?
    I have Vag com, but i have not used it as yet..
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    yup vagcom will do it or some garage reset tools
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    Now to many mods to list! Lots of power, torque and Leather!
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,365
    not read the link above, but you don't need vagcom or garage tools to do this, it even tells you how to do it in the manual!
    Hold in the left stalk and turn the ignition on whilst holding it pressed in, fiddle about with both stalks until you figure it out.
    job done, takes about 15 seconds.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    i tryed that with my A3 and it never worked
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,365
    it does work, 100%. if it doesn't, you're doing it wrong
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Yep, when I have serviced mine I have reset it this way.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    even on the pre facelifts? must of done it wrong then
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Quote Originally Posted by ALPINE View Post
    Works on my X-reg prefacelift.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    must of done it wrong then.+
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    It is in the manual, am pretty sure the instructions are already on here, it can be done just by the dash, ive done it a few times and it defo works.
    May 2009
    123
    what do you mean pushed in? which direction?
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Quote Originally Posted by Zenin View Post
    Pushed "In" as opposed to pulled "Out"
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    To add to what prawn said;
    RESET SERVICE INDICATOR:
    *Switch off ignition.
    *Press right hand button on dash and hold while switching on ignition.
    *The display should now read SERVICE!
    *Immediately press and hold the left hand dash button until SERVICE! is cleared from the display (some cars you need to twist to the left instead).
    CHECK MILES TO NEXT SERVICE:
    *Check distance to next service with Left button (ignition on).
    * The display will read SERVICE IN XXXX MILES. (Some cars you need to press the right hand button on dash and hold while switching on ignition. Don't press or twist the left hand button now or you might reset the mileage!)
    NOTE: You need to have the doors shut for the above otherwise the open door symbol will overwrite your service indication! The service indicator can't be reset until the countdown miles says SERVICE or SERVICE in XXXX miles. If you need to reset the service indication before the countdown expires, possibly on some cars you may need to use VAG-COM - or wait until the countdown reaches zero and says SERVICE.
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Chugger
    North Devon
    2,716
    this is in the cars manual
    57 A3 2.0 TDI Sportback (140)
    nath-w's Avatar
    Mar 2009
    134
    i have just been trying this for an hour in my car and eventually managed to turn off the service light, but i had to do it different from what people say on here and different from what my manual says. i had to hold in right button, then turn ignition on, then immediately pull OUT the left button and keep it pulled out until it says; service - - -, then i had to turn ignition back off still whilst holding out that left button, hope this helps someone who is struggling with turning off there service light!
