mark_sarah
Limp mode!
As the title says, how do you remove the service light on the cluster?
I have Vag com, but i have not used it as yet..
not read the link above, but you don't need vagcom or garage tools to do this, it even tells you how to do it in the manual!
Hold in the left stalk and turn the ignition on whilst holding it pressed in, fiddle about with both stalks until you figure it out.
job done, takes about 15 seconds.
it does work, 100%. if it doesn't, you're doing it wrong
even on the pre facelifts? must of done it wrong then
what do you mean pushed in? which direction?
