EM TuningAH Fabrications
Results 1 to 8 of 8
    123holah's Avatar
    61
    fitting S3 8P brakes to S3 8L?
    Hi as i have been looking to upgrade my brakes i was wondering if its possible to fit standard front brakes (calipers and 345mm discs) off a new style S3 to my 2002 S3?
    how much work is required if anyone has done it before and will i need adaptors? i was looking at brembos but i know of a local breakers where i can get the new style ones much cheaper than porsche brembos etc.
    advice please?
    2002 S3, Kingfisher Blue, Custom code stage 1, Forge 007p, Green cotton filter, almost all factory extras!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Been discussed before pretty much... IIRC the calipers are the same but the discs are bigger which won't fit anyway as they are 5x112 PCD and not the 5x100 PCD of the 8L.
    Best budget upgrade to 8L brakes IMO is Ferodo DS2500 pads, decent after market grooved discs and Motul RBF600 or 660 brake fluid.... beyond that its 4 pots but not Porsche Boxster/996 rear calipers as many people may have recommended as they are ****e...
    <tuffty/>
    123holah's Avatar
    61
    ok then, thanks that puts a stop to that! i was just looking around and thought they would look like OEM parts.
    i think i will stick with decent replacenent discs and pads for now as advised.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    you could swap hubs over to, this would allow fitment of the correct discs but then you would need to have the correct wheels.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    So from that, you know the hubs fit direct?
    I thought they were completly different setups? little did i know huh!
    I spose you could have the discs redrilled, but it ever worth it for no real gain,unless the discs are massivly different in size to 312's
    SteveBAM's Avatar
    Black '03 S3
    Sep 2009
    A, A
    180
    i did something like this http://www.audi-sport.net/vb/showthr...ipers&p=975875
    calipers from EVO X, not saying you do the same but there are plenty of options out there, just depends on your budget and time frame..
    RIP S3dave
    May 2004
    nr Glos
    7,187
    Quote Originally Posted by SteveBAM View Post
    you can hardly call this a kit, as you had to have a chunk of machining done to make these up... which is all well and good if you have the facilities & skills, but if the OP does'nt this is not an option at all
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    123holah's Avatar
    61
    the new style s3 discs are much bigger at 345mm (barely fit into 17's) and from the research i have done the calipers are quite a bit bigger so if they were an easyish swap it would have been a good upgrade. as it is, it sounds too much hastle and for what it would cost i would be as well to go for tried and tested brembos (911, junior GT etc)
    as it is i have had the car 8 months so i will see how upgraded discs and pads suit me and upgrade again in the future if i feel the need!
