Sky InsuranceChris Nott
Results 1 to 8 of 8
Thread: piston rings
    Sep 2009
    50
    Question piston rings
    Anyone ever changed them? (not just on an a3)
    had blue smoke quite severe out my exhaust and i think i've came to a conclusion that there has been grit left in the piston shafts when i recently changed my head gasket, and its worn down the rubber and allowed oil through...
    can anyone tell me anything about it? willing to do the work myself, just need to know whether the head has to be split and i have to do the whole head gasket thing again or if its the whole block that comes out. and were i can get the parts from etc..
    anything really.
    thanks in advance
    Audi A3 97' 1.6 Midnight Blue | Standard as of yet |
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    So you want to know how to change rings on a 1.6 A3?
    Are you sure the HG job was done correctly?
    As i am not being funny, you seem to have a pretty poor grasp of what is going on and what things are called, you may be better leaving to an "expert" to help you/do it
    Sep 2009
    50
    I know what i meant, maybe it just never came across proper cos i was typing it on my phone.
    and no the head gasket job was fine as it shows no symptons of that.
    and as for taking the car to an expert, that would cost more than the car is worth, and i am willing and capable of doing it myself.
    can anyone be of any 'actual' help?
    dont need a full step by step, just a rough idea of the process? troubles? parts?
    Apr 2004
    12,520
    Quote Originally Posted by lugz View Post
    parts?
    I suggest if you want a constructive answer you refrain from giving attitude to those that bother to post on your thread.
    I would remove the engine to change the rings tbh as its not that hard, then whack the head off and the sump to drop the crank. It can be done with the engine block still in the car but care needs to be taken when honing the bores as its easy to catch the webbings when doing the bottom of the bores. I would also for the cost look at changing the shells.
    The head has to come off either way you do it, no way around it sadly
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    piston shafts
    WTF is a piston shaft?
    What rubber?
    Homer Simpson
    Alex C's Avatar
    Lizard, Cornwall
    2,599
    piston shaft = cylinder ??
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Cookstein View Post
    Ahhhhhhhhhh. I see. Makes a spot more sense now....
    Homer Simpson
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,554
    ...What rubber?
    The piston rings???
    If you think the bores are scored from grit then you may have a bigger problem tbh... honing 'may' get them out but you may end up needing a rebore which will then need new pistons and rings which will need to be gaped and new big end bearings as you will need to remove the rods to get the pistons off, new head gasket, new head bolts and fresh oil.
    Not a small amount of work so I would get a second opinion on where the oil is coming from before committing tbh... it could be the valve stem seals too....
    It could also be from overfilling the oil as well... if you have too much oil in the engine from overfilling it will get pumped out the PCV system back into the intake and burnt by the engine.
    <tuffty/>
