Definately.. Thats stuff is THE sh*t! it will stick anything to anything with great strenght. Dries about as hard as the rubber on your wheels! best to stick onto rough surfaces though so roughen the 2 mating surfaces slightly first!
sold at most motor factors or from bodyshops and iirc B&Q
If your planning to remove the skirts than a strong double sided tape will work (although with the right solvent sikaflex is supposed to be easily removed)
