Volks AutosAH Fabrications
Results 1 to 11 of 11
    May 2010
    15
    Fault code advice
    Hey chaps,
    Just bought an s3 and put it through a pre-purchase check. It came up with three faults and i'm wondering if anyone can point me towards a part/solution to fix them, and also the impact they have on the car?
    Faults as follows:
    Gas temperature sensor
    Main relay open circuit
    power supply too high
    Any help would be great!
    Cheers,
    Iain
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    bought already? do a search and post up the specific errors.
    well come to the forum
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Do you have the fault codes? The descriptions given are not enough really as there can be several different faults of any given component and will need it in context to begin to understand whats going on...
    <tuffty/>
    May 2010
    15
    Cheers for the replies guys. I've asked the garage for the fault codes, they posted the report through to me just with the description. Was hoping someone recognised the description - i'll post what i get back...
    May 2010
    15
    Hey guys, got the additonal info through
    Gas Temperature P1455, P1456
    Main Relay circuit : P0688
    Power supply too high: P1602 (a new battery was fitted not that long ago, could this be connected?)
    Any tips/info would be great, cheers,
    Iain
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Not using VAGCOM by the looks so makes it a little trickier to find info based on half the codes sadly but...
    17072/P0688/001672 - ECM Power Relay Load Circuit: (J271): Open Circuit
    Possible Symptoms
    • Engine Coolant Fan running at full Speed while Ignition is OFF and Engine is COLD (could lead to discharged Battery)
    Possible Causes
    • Fuse(s) faulty
    • Power Supply Relay for Engine Control Module (J271) faulty
      • Terminal 87 faulty/hanging
    • Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271) faulty
    Possible Solutions
    • Check/Replace Power Supply Relay for Engine Control Module (J271)
    • Check Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271)
    • Check/Replace Engine Control Module (J220)
    http://wiki.ross-tech.com/wiki/index...2/P0688/001672
    18010/P1602/005634 - Power Supply B+ Terminal 30: Voltage too Low
    Possible Causes
    • Cables on the Battery were removed
    • Battery weak (voltage)
    • Generator Disfunction
    Possible Solutions
    • Check Battery Cables
    • Check/Replace Battery
    • Check/Replace Generator
    Special Notes
    • If multiple Control Module have Power Supply Faults stored, it's most likely to be one common Problem like the ones shown above. Otherwise when only one or two Control Modules have such Codes stored you better start searching at the individual Power Supply of these Modules.
    http://wiki.ross-tech.com/wiki/index...0/P1602/005634
    Not sure about the EGT one, can't find a reference on Ross Tech Wiki, closest I could find was...
    17863 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
    P1455 - 35-10 - - - Intermittent
    Ross Tech Wiki doesn't have a page ref for 17863 but check that the EGT probe is plugged in for a start... EGT black box is under the inlet mani, remove the small trim cover (2 screws) and there will be a plug to the left hand side as you look... if unplugged then this would be the prob.. if not then EGT probe could be inoperative...
    Try and get the cars fault codes read by VAGCOM as it provides much better info than most 3rd party handheld devices....
    <tuffty/>
    May 2010
    15
    Thanks tufty. Not familiar at all with the 8L S3 so i've sent your advice to the garage and asked them to investigate - away to hit a learning curve!
    Feb 2009
    Aberdeen
    2,489
    http://www.seatcupra.net/forums/show...=254738&page=1
    Faulty temp sensor, or wiring to it... apparently.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    May 2010
    15
    Thanks, how would I find out what part number i need to buy?
    Feb 2009
    Aberdeen
    2,489
    Head in to Audi/call and ask? (01224) 400500 - they're pretty helpful. When I went in last time the guy brought through drawings s I could point out exactly which gaskets I was after. You could try googling, or maybe search the forum for someone after the same thing.
    Hunt is over
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    EGT sensor is around the 180 mark... I managed to source one from ebay.de but there is little or no discount to be had... even TPS couldn't get it below that kind of price...
    I would be making sure it is the probe itself and not a wiring issue before changing it. The EGT probe control box is under the inlet mani, the probe itself and a type K thermocouple and is screwed into the turbo's hotside just below the actuator arm.
    Get it on VAGCOM to double check the exact nature of the fault and start from there... replacing the sensor without making sure the sensor is at fault is an expensive way of ruling it out as a problem in this case...
    <tuffty/>
