Volks AutosBadger5
Results 1 to 7 of 7
    Oct 2009
    73
    Engine Emmision Light on, Please help
    Hi all,
    I have a 2000 Audi A3 1.8 T-Sport that has done 62,000 miles.
    The engine emmision light has come on and Im not sure whats wrong with it.
    It drives perfectly normally, the only thing thats wrong is that when ticking over the revs flick about a lot and it sometimes sounds like its nearly stalling. Also my fuel economy seems a bit lower than normal.
    Any advice as to what it could be would be much appreciated.
    Adam
    Oct 2008
    Sunny Suffolk
    69
    get it on vagcom but i would guess a dodgy MAF im sure someone will be along shortly to confirm.
    Try unplugging the MAF and see if it runs any better.
    76
    could be a lambda sensor on its way out, most likely to be the one after the cat.
    Wouldn't have thought a dodge maf would throw up the emissions light but i could be wrong.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    vagcom scan
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Oct 2009
    73
    I had a new MAF sensor about 4 months ago so im certain that is ok.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Ibiza Cupra TDI
    Gone:
    Audi 8L S3 - Revo'd
    toathus's Avatar
    Mar 2010
    27
    It could just be a split pipe. Have a look under the engine cover and check for any perished pipework
