Monster MotorsportEM Tuning
Results 1 to 18 of 18
    Jul 2009
    Saltburn by Sea
    67
    Magnecor plug leads?
    My A3 1.8t is badly in need of a service and is misfiring. I've used Magnecor on other cars but can't find them listed for the A3 1.8t. Has anyone used them or can anyone recommend similar. Will be replacing plugs too if anyone has any recommendations.
    RIP S3dave
    May 2004
    nr Glos
    7,139
    you have coil on plugs no leads...
    where do you think you will be putting the leads from and too?
    there's a reason they're not listed
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Jul 2009
    Saltburn by Sea
    67
    Ah, never had a car that didn't have leads, I just assumed! So what's likely to be causing the misfire then, I lost about half power last night then on the way home it cut out for a second then came back.
    RIP S3dave
    May 2004
    nr Glos
    7,139
    coil packs... they are shocking things for failing..
    other common parts which can fail being MAF (mass air flow) meter
    misfire usually under load (boost) when they start to fail, and once popped they drop that cylinder.
    check your plug gaps.. If too large (0.7mm ideal) then the extra gap the spark has to jump, can cause an older, more frail coil to "pop"
    25-30 per coil pack - beware of non OE parts
    good luck
    bill@badger5.co.uk
    Jul 2009
    Saltburn by Sea
    67
    That's what's happening, it feels like it's running on 3 and down on power when you go to accelerate.
    RIP S3dave
    May 2004
    nr Glos
    7,139
    coil pack gone.. sounds like to me
    sound like a scooby now too?
    unplug the injectors one by one to determin which one has failed.. my advise is replace all 4 @ same time
    bill@badger5.co.uk
    Jul 2009
    Saltburn by Sea
    67
    What is a good make to go for? Europarts list 4 different ones.
    RIP S3dave
    May 2004
    nr Glos
    7,139
    I personally only use Oe coil packs
    bill@badger5.co.uk
    Sep 2009
    Essex
    2,366
    thats what i said a tried i was poking fun at after he had a few fail. with his car, his coil packs were all sparking on idle so you didnt notice a difference when unplugged individually but pack was misfiring like a mofo
    Sep 2009
    Essex
    2,366
    OE are made by BERU id expect
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    The OE ones are BERU, the OE spec ones from Euro come in a VAG box and are made by BERU
    Change all 4 and forget about it
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Matt82 View Post
    Hitachi I believe dude, well my OE ones are.
    Homer Simpson
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    hmmmm, interesting. Mine have the 4 rings on the top and also BERU?
    May 2006
    Lancs
    211
    When I replaced one earlier this year it had Pulse written on the top I think. The older ones all say Bremi and are a slightly different part number.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    It might also be the ignition amplifier if its an earlier engine. Early motors had a seperate ignition amp, and a "dumb" coil. Later engines have a combined amp and coil on each plug.
    TD5 Land Rover Defender build
    Jul 2009
    Saltburn by Sea
    67
    Annoyingly the problem has vanished now. I wonder if it will have recorded any faults on the VAG COM?
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    i m sure oem coil packs are still made by bosch
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    regardless you wont get the newest version from Euro, what ever difference it makes the dealers are always that one part number ahead and cost approx 2-3 more...get ya hand in ya pocket
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
