Volks AutosJMB Retrofits
    S3PEG's Avatar
    Bristol
    99
    Oil leak at rear end of car
    I seem to have oil leaking from the back end of the car (next to the back box) is this from the diff? Could it cause a slight grinding noise when dipping the clutch to change gear when the engine is cold?
    Thanks!
    S3Peg
    Black S3, APR Chip, EBC Brakes, 18" RSTT's.
    Sep 2009
    Essex
    2,366
    the only thing that far back that would have oil should be the diff... or a split CV gator dropping grease out.
    or a muffler bearing
