EM TuningJMB Retrofits
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By anderswhk
Thread: Air vent removal
    Keefy's Avatar
    Feb 2009
    Bristol
    124
    Air vent removal
    Hi all,
    Yesterday noticed there's a rattle coming from the passenger side air vent as I go over bumps - on closer inspection it appears that a tiny shard of plastic has broken off the inside of the vent grille and is rattling around in there somewhere. I've had a poke around with some long pliers and tweezers but to no avail. Looks like the vent is going to have to come off.
    Had a little pull but it's not budging. I'm not sure if it's just a bit stiff or if there are clips that I've missed? Not keen on trying too much harder as I don't want to make a mess of the interior. Looked on some of the vent-based boost gauge threads but there's no info on actually removing the vent grill. Should I just give it some or is there a special way of removing them?
    '01 Facelift S3. CC'd by the Badger
    S3 Paul's Avatar
    Oct 2006
    2,764
    I asked this a while back,
    So the thread should be somewhere... basicaly it involved making 2 hooks that just fit through the gaps in the vent... one top and one bottom. they latch over the back of the vent housing ( about 3 inch inside the vent ) and this allows you to pull the vent free. If a search brings you no results i will take a picture later and upload it
    Noggy Blue 2001 S3
    Keefy's Avatar
    Feb 2009
    Bristol
    124
    Found it after quite a bit of searching, cheers!
    Here's the link if anyone else needs the info: Removing drivers air vent
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Sep 2012
    17
    I just have bought Audi A3 1999.. The passenger air vent is borken, can someone help me how to change it?
    Feb 2012
    Denmark, Copenhagen
    205
    How is it broken Zero? Wont open, or air wont come out?
    ZeroOne likes this.
    Sep 2012
    17
    mn6S1UPILizTp5z_8Pi2Svg.jpg one of this are broken.. so how can I remove this all, not just the part which is broken..
    Sep 2012
    17
    Do you understood me ?
    Feb 2012
    Denmark, Copenhagen
    205
    You need some trim removal tools, which is usually red plastic and you can gently take it out. Then the entire unit comes out. If you have a facelift A3 (With red lights in the vents) you will need to do some solering. Shouldnt take any more than 15 minutes.
    ZeroOne likes this.
    Sep 2012
    17
    But some pictures or video, what kind of trim removal tool ?
    Feb 2012
    Denmark, Copenhagen
    205
    It is just pieces of plastic to remove plastic trim such as the dashboard without scratching and damaging it.
    Sep 2012
    17
    How looks that pieces of plastic?
    Feb 2012
    Denmark, Copenhagen
    205
    just google trim removal tools
