17745 P1337 Camshaft Pos.Sensor Bank1 Short to Ground
errrrrrrrrrrrm replace it, £29 quid
17745/P1337/004919 - Camshaft Position Sensor (G40)
17745/P1337/004919 - Camshaft Position Sensor (G40): Short to Ground
Possible Symptoms
  • Malfunction Indicator Lamp (MIL) active
Possible Causes
  • Camshaft Position Sensor (G40) faulty
  • Wiring/Connectors from/to Camshaft Position Sensor (G40) faulty
Possible Solutions
  • Check Camshaft Adjustment
  • Check Camshaft Position Sensor (G40)
  • Check Wiring/Connectors from/to Camshaft Position Sensor (G40)
i recon the timing between cams is out. 16 rollers between gears and both squares on the cam in line with the arrows on the cam bearing caps. It's a pain as you can set it, but when the tensioner fills with oil it pulls it out of time.
Obviously this is assuming the main crank/cam timing is accurate.
