Badger5JMB Retrofits
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    17745 P1337 Camshaft Pos.Sensor Bank1 Short to Ground
    How do i fix this code as my timing it is now done but getting this code but drives like a bag of spanners
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    errrrrrrrrrrrm replace it, 29 quid
    17745/P1337/004919 - Camshaft Position Sensor (G40)
    17745/P1337/004919 - Camshaft Position Sensor (G40): Short to Ground
    Possible Symptoms
    • Malfunction Indicator Lamp (MIL) active
    Possible Causes
    • Camshaft Position Sensor (G40) faulty
    • Wiring/Connectors from/to Camshaft Position Sensor (G40) faulty
    Possible Solutions
    • Check Camshaft Adjustment
    • Check Camshaft Position Sensor (G40)
    • Check Wiring/Connectors from/to Camshaft Position Sensor (G40)
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Jun 2009
    Leeds
    3,472
    Check Camshaft Adjustment ?
    I have a spare sensor
    It was running fine before i did the timing
    FOR SALE
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    i recon the timing between cams is out. 16 rollers between gears and both squares on the cam in line with the arrows on the cam bearing caps. It's a pain as you can set it, but when the tensioner fills with oil it pulls it out of time.
    Obviously this is assuming the main crank/cam timing is accurate.
    Jun 2009
    Leeds
    3,472
    Would the timing cause it to smoke?
    This is starting to piss me off with all the problems
    FOR SALE
