Badger5Chris Nott
    Pete20vt's Avatar
    Supermoto Junkie
    Apr 2010
    Stroud Gloucestershire
    122
    Question Clutch Pedal Switch Issues...
    My car started revving between gear changes, unplugged the clutch pedal switch gave it a clean and put it back and the problem stopped instantly, but a day later it was playing up again. Fitted a new switch today but no change??!! I'm 99% sure the problem is switch related as it seems to directly affect the performance whenever a mess with it. But i cant seem to cure the problem permanently, is there a 'correct' way to install the switch, ignition on/off, clutch pedal depressed or not?
    FOR SALE: 2003 RED Audi S3 - 73k - MINT - Custom-Code - Black Leather - £6600
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Here's a link to a guide that I used, albeit for a brake switch but the theory behind fitting it is the same:
    http://forums.vwvortex.com/zerothread?id=1158315&page=1
    Imteyaz.
