Chris NottEM Tuning
Results 1 to 14 of 14
    s3gav's Avatar
    Jul 2009
    414
    replacing broken dipstick pipe?????
    ive been stupid today i took my throttle body off as i had a split hose and wanted to clean it up and i managed to snap off the dipstick pipe.
    how easy is this to change?
    can it be done from the top or do i need to get under the car?
    SOLD 2002 S3,full black heated leather, bose, 997 turbo's, lcr splitter, coilovers, superchip, blueflame cat back, k&n, forge dv, forge hoses, forge quickshift, forge rear tie bars and forge fmic
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    just pull it out mate..there well in but they are just pushed on. molegrips are your best buddy! think the dip stick thingy is 3 from the steelers. done the same with mine
    Now to many mods to list! Lots of power, torque and Leather!
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    I done mine recently 8 from main dealer, apparently they have a short life span. They do just pull off from the top, and simply just push the new one on. Takes about 5 minutes to do.
    s3gav's Avatar
    Jul 2009
    414
    thanx guys
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by mark_sarah View Post
    8.. oh ill feel privillaged i only payed 3 nuggets!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    They go hard over time and snap off at the bottom... found the best way to remove to prevent bits from entering the sump is to use a long screw driver (or similar) and a hammer to push it off from underneath... should come off easily and in once piece...
    <tuffty/>
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    i put a pipe brush, bong brush, whichever you would like to call em down mine. any bits fall down the pipe, they sit on the bristles. pull it out and the bits come with it.
    s3gav's Avatar
    Jul 2009
    414
    luckily mine has broke about half way down i will try pulling it tommorow night.
    paul is it easy to get underneath it and tap it out if pulling it doesn't work?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Quote Originally Posted by ALPINE View Post
    Good idea
    Quote Originally Posted by s3gav View Post
    You have to remove the undertray to see it... left hand side of the oil filter looking from the front... get the car on ramps or stands then gently tap... there is a lip in the metal part of the tube going into the block just where you need to tap the bottom of the dipstick tube... make sure the long tapping device is on the orange plastic part then tap away...
    <tuffty/>
    s3gav's Avatar
    Jul 2009
    414
    <tuffty/>[/QUOTE]
    thanks tuffty will give it ago
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    3.40 from Audi
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Dec 2006
    84
    3 ish from main dealer.
    A gentle upward twisting force is
    all that's needed to remove.
    Accessed from the top of the engine, a pair of long, angled nose pliers is ideal for the job.
    martin g's Avatar
    [censored]
    somerset
    154
    I took the oppertunity of a broken one to make a minor mod. Mine broke near the bottom so i removed the whole thing, cleaned it up and re-joined at the break with flexible heavy duty rubber repair tape. Its a solid fix but now the tube has a pivot/springy point low down which means its now flexible and can be pushed to one side without breaking. It was meant to be temporary but has lasted and seems to work well.
    s3gav's Avatar
    Jul 2009
    414
    thanx guys
    will attempt it shortly
