tompearson
It's all in bits
I am thinking of getting a Forge UNOS boost controller to drive the actuator on the BT set-up I am currently trying to sort out. Has anyone else got one, and if so would they recommend it and how have they plumbed it in. I am assuming I would the take input from the charge pipe with the output obviously being the actuator (I.e. the tip connection that I would require if I used an N75 is no longer needed). Equally are there any other recommended boost controllers? (that don't cost £XXX)
On the same theme, if I simplify the PVC system and put in a catch can, is the free port (what was the crankcase breather) on the inlet mani good to run a boost gauge off?
