Chris NottEM Tuning
Results 1 to 28 of 28
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Forge Splitter DV - Who's running one?
    After much debate about which re-circ valve to go for, for my s3, i went for the Forge 007p as so many people bigged them up.
    I didn't want something too loud but the 007p is too quiet and i want something with a bit of 'presence'.
    I hear the Splitter is an Atmospheric type valve.
    Now i don't wanna hear everones 'opinions' on them, i just want feedback from people who have used, or currently use one as i have heard a few negitives as well as positives :-)
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    my mate Ash runs a splitter on his ko4`ed mk4 golf. as far as im aware he has never had no problems, but his car was mapped with this on.
    hope this helps
    Now to many mods to list! Lots of power, torque and Leather!
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Thanks dude, i know they obviously can't be 'bad' as such as i'm sure they wouldn't be being sold by such a reputable motorsport company like Forge if they were.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,637
    Visit s3 Hoggy's Instagram Channel
    I have read alot of threads were people have fitted theses splitter valves and had problems with them, I have no experience myself though mate
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    Pete20vt's Avatar
    Supermoto Junkie
    Apr 2010
    Stroud Gloucestershire
    122
    Try a BMC CDA induction kit along with either a 007p or a bailey Dv26 (i think), i had that setup on an Ibiza Cupra and the woosh was very loud especially for a recirc. I think the most part of the sound was the echo of the air around the carbon tube of the BMC CDA as the woosh you hear comes back out from the filter rather than the DV itself.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,941
    want wooshy noise, fit an open induction kit and keep your 007p dv
    splitter valve is with all due respect to forge is not a good product.
    forget bmc filter unless you want to loose airflow and performance...
    15g/s less on cda than on open cone.. it strangles the 1.8t - nasty thing
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Pete20vt's Avatar
    Supermoto Junkie
    Apr 2010
    122
    Made a good noise though
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    I already have an Evoloution Motorsports Intake, which if you havn't seen one before is an open cone within a housing that seals against the bonnet. Just doesn't create the noise i want.
    why do you regard the splitter as being a 'not very good product' dude??
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    This...
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    I might be wronge but doesnt the splitter dv come with a blanking cap that you can screw on,
    so all the pressure goes back into the TIP,
    which would make it the same as the 007p dv ?
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Don't waste your money on a BMC CDA as they are restrictive.... Had an S3 in with one on and swapping to a cone filter gained substantial airflow....
    Just fit a panel filter such as the Green Panel Filter and you will hear more noise...
    Split R or any type of atmospheric valve shouldn't be used on a 1.8t... I have gone into this subject at length before but it will end up causing running problems as atmospheric valves vent metered air (by the MAF) which the ECU has already calculated fuelling and the like based on the air its measured... normal DV's recirculate the air when in operation so the same volume of air is present... Split R type valves only parially recirculate metered air and will cause engine hesitancy and juddering...
    If your car is not mapped you are unlikely to hear anything anyway as there isn't enough pressure to make that much noise but a panel filter will make a difference as will a remap...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Quote Originally Posted by dannycawsey View Post
    It may do but what is the point in that? You may as well go for the cheaper 007p and get it right first time
    <tuffty/>
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    CHAVVAY
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Had one on mine for over 2 years, doesn't seem to have any effect for me either positive or negative.
    If you want to swap your 007p for it pm me
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    I'm most likely going to buy one and see the differences in it. if i'm happy then i'll shift the 007p on.
    IanW why do you want to swap for a 007p then if you're happy with your splitter valve?
    fran-s3's Avatar
    1,090
    007p on mine with green panel and i drilled some holes in the OEM aribox under the filter away from engine to create more of a wooshy ness on lift off... (I didn't go mental on it as I didn't want it to loud but the bigger the holes the bigger the woosh obv) I haven't noticed a performance loss in hot weather when I did mine last year.... smoothing the airbox and defining though would have helped and removing the trumpet. Just a cheaper alternative if you fancy it.
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Quote Originally Posted by SamiG View Post
    As I sad i'm neither happy nor dihappy with it, I never have my window down and really couldn't tell you if it makes a swoosh sound or not, just thought you might of wanted to do a straight swap, doesn't bother me if I run a Split R or a 700p, Split R was all that was in stock when I bought mine.
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Have you got your splitter in recirc or atmospheric mode then??
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Turn the 007P around mate.... This means, take it out and pipe it the opposite way.
    This makes it louder.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Already tried that mate, no louder and just makes a strange squeaky noise : /
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    LOL, there's your problem. There must be a mouse in there somewhere....
    Homer Simpson
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    007p and a carbonio CAI. Sounds lush! mine has followed me between cars. its just not the same without it :D
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    Forge 007p, Pipercross panel, silicone TIP and remap - plenty of whoosh!
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    yep i agree....enough whoosh and if it isnt, couple of small holes in the airbox will create that, although too many will actually reduce it as the pressure will reduce
    Tssssst = chavtastic, simple as
    www.badger5.co.uk
    May 2004
    nr Glos
    6,941
    its a compromise of recirc and open dv... so when in use its main boost is always vented in recirc before the atmos port is opened up... and there's little boost left to vent which is a quiet atmos dv..
    bill@badger5.co.uk
  28. #27
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Adding to that, they require constant adjustment and aren't very reliable.
    Homer Simpson
  29. #28
    Apr 2009
    Preston
    243
    Quote Originally Posted by JS1500 View Post
    Exactly what he says ^^^^^^
    Mine sounds like a coo'ing dove at times. Blanked my Splitter-R off too
