Volks AutosEM Tuning
    Oct 2009
    34
    Actuator question
    Ive noticed that I can manually move the actuator but have been told this should not be possible,do I need a new one?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,469
    Depends on your definition of 'manual'... a std K0x actuator can be moved by hand but takes fair bit of effort and leverage... if you can move it simply by fingertips then yeah something is wrong... however it should be noted that actuators are pressure fed and so shut by a spring. Springs do go soft but I have not heard of one breaking or going soft enough for easy movement... the diaphrams can split which means they won't open very well if at all when pressure is fed to them by the N75...
    These items rarely go wrong tbh...
    <tuffty/>
    Oct 2009
    34
    I can move it by hand with little effort by this I mean I can pull the bar away from the actuator also it moves when I apply revs when stationary.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,469
    So, in the pic below, the actuator on the left... you can move the rod coming out of the actuator by hand easily?
    <tuffty/>
    Oct 2009
    34
    yes thats the one mate!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,469
    humm... shouldn't be moving like that by hand if I understand you correctly... what other symptoms do you have with the car?
    <tuffty/>
