Badger5JMB Retrofits
Results 1 to 24 of 24
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    Ball joints, cv boots, bushes & bearings
    As title does anyone know how hard or have a guide to do em ?
    the bushes would be for the front Wishbone Rear Bush & the bearings for the rear.
    thanks
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    ball joints are easy , cv boots a little harder but ok if your used to spanner work just get audi kit imo
    never done a bearing on the audi but might be part of hub some are some are not
    red to red black to black blue to bits
    Nov 2005
    UK
    1,688
    i assume if your doing a balljoint its quite straight forward to do the boot also
    wanted for 8L S3:
    Milltek system
    thats me
    Sep 2004
    west yorkshire
    3,762
    If you done cv joints in the past its straight forwad, Id recommend the right tool for the metal clips on the boot they can be got for 8 for a sealey tool. You have to disconect ball joint to do cv boot. Think the center bolt is a 17mm allen key sorry if a bit sketchy I then to do things on the fly
    Nov 2005
    UK
    1,688
    could do with a guide really, i know once i get down to it there ll be no problem however just need more some guidance.
    wanted for 8L S3:
    Milltek system
    beachbuggy's Avatar
    Surrey
    1,744
    CV boot replacement
    I've just had to replace a cv boot on my A3. It's a bit of a pain, but can be done in a couple of hours.
    I should have taken some pictures, Sorry
    But can give a rough guide, it's not that difficult just fiddly and typically the lower the cost of the part the harder it is to replace. Not even sure if its the best method but it worked for me anyway.
    CV boots, come in a kit form. Got mine from Eurocarparts, 10 each for the kit, this includes a Boot, clips, bolt and grease. You will need both the inner and outer, if you are replacing the outer boot and only the inner if that one has gone, basically to get the outer of one you need to remove the inner one to get to it.
    Also while you're at it, you may as well change the wishbone bushes. THey are very easy to get too once the suspension arm etc is out the way.
    Basically you need to remove the drive shaft to get to the boots.
    1) If you have a wheel with a centre cap, remove this. using a 30mm socket undo the centre bolt holding the prop shaft, then remove the wheel and jack the car up.
    2) Compress the springs( not sue if this is really required but certainly helps and stops the risk of the shocks kicking back at you and undo the top suspension mount.
    3) Undo the the steering control rod and ARB
    4) Undo the 3 small bolts in a V shape holding the lower wish bone on.
    5) Undo the brake caliper, abs sensor and secure up so not to damage the pipe.
    6) Remove the whole suspension arm including damper.
    7) The other end of the prop shaft is connect to the gear box by 6 Hex screws, Undo these with the appropiate allen key with an extension. You may need to turn the engine over as only some of the bolts are accessible at once.
    8) once the 6 bolts are undone you can now remove the prop shaft.
    9) At the end which goes into the gearbox there is a metal dome cap, with 3 clips fold over the end of the prop shaft, Prise these open and remove the cap, noting that the dents they are located in.
    10) push the prop shaft up to expose the end of the shaft, remove the grease and you will see a C clip on the end. Remove this and gently tep the end of the prop shaft off. It's on a teethed spine and will come off with a gently tap.
    11) not you can remove both the CV gaitors and replace using the clips included and the grease supplied.
    12) putting back to together is just the opposite, Howver don't worry too much about the domed cap mentioned in stage 9 being as tight as it was when you took it off as it's compressed when you bolt the shaft back up.
    If I've missed anything sorry but hopefully it'll get you started.
    Sep 2009
    Essex
    2,366
    rear bearing was
    wheel, calliper, disc off
    undo the hubnut and then the hub/bearing can be removed.
    put the abs ring on the new hub (if it didnt come with one) and then reverse the above process.
    yuoll need a big torque wrench/breaker bar to get the old bearing/hub off though
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Good guide above, although it can be done much much easier I think.
    I replaced my CV Boot and Ball joint last week, this is how I did it.
    removed the wheel centre cap
    undo the bolt connecting the drive shaft to the hub then the wheel bolts
    jack up the car
    remove the driveshaft from the hub
    undo the 3 bolts at the bottom of the wishbone (hub side)
    undo the bolt joining the ball joint to the hub (may need a ball joint seperating tool, I did)
    Ball joint should be free to remove.
    now remove the old cv boot and clean out the old grease
    Using the cv boot cones you can buy, cover it in MR Sheen polish so its really easy to slide the boot over joint (make sure the boot is inside out)
    Once the new boot is over the joint, fill it with grease
    attach the boot with the clips provided
    Put it all back together (do not tighten the ball joint don to much as it will split)
    Thats how I did mine. real easy Job done.
    Nathan
    Nov 2005
    UK
    1,688
    I ve had a quote for the following work
    2 x ball joints supply & fit
    1 x cv boot supply & fit
    2 x rear wheel bearings supply & fit
    Fit front ARB
    total 620
    I think thats excessive its a private job no friend of a friend (techie)
    wanted for 8L S3:
    Milltek system
    Chugger
    North Devon
    2,716
    well genuine ball joints and bearings are pretty expensive. Its all pretty easy, Iv never done wheel bearings but dont think they are too bad.
    57 A3 2.0 TDI Sportback (140)
    Nov 2005
    UK
    1,688
    depends what you class as exspensive vwspares do them for about 25 per side, rear wheel bearing are a similar price cv boots are 30 max
    wanted for 8L S3:
    Milltek system
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    I paid 10 for my cv boot kit. Ball joint 23 from euro parts.
    You could do all that in a afternoon. I havent changed a front arb but shouldnt be to hard, most people drop the subframe though.
    Nov 2005
    UK
    1,688
    yeah i totally agree i could probably do all that its just having good guidance like a 'how to help me' would probably need a torque wrenchas well & bearin press (which i havent a clue about)
    wanted for 8L S3:
    Milltek system
    Ross_S4
    Aug 2009
    Dundee
    718
    get a copy of elsa off ebay.
    they are so cheap its only the price of a few pints. with the age of our cars we don't even need the latest versions.
    Nov 2005
    UK
    1,688
    does elsa win tell you what tools are needed & providetorque settings etc ?
    wanted for 8L S3:
    Milltek system
    Apr 2009
    Preston
    245
    My front drivers boots has sprung a leak / pissing grease everywhere.
    GREAT! not :|
    Are they the same CV boots used on A3's? or do you need an S3 boot?
    Get one from Autoparts you say?
    Or direct from Audi? (and if Buying one direct from Audi)- Will it come with the same kit/ grease/ clips etc needed to replace?
    Thanks,
    Joe
    Nov 2005
    UK
    1,688
    hey i dont even know what sort of grease i should be filling the boot with
    wanted for 8L S3:
    Milltek system
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    When having the ball joints done, you WILL need to get it tracked after.
    Homer Simpson
    thats me
    Sep 2004
    west yorkshire
    3,762
    Quote Originally Posted by djarchive View Post
    GREAT! not :|
    Thanks,
    Joe
    Audi ones come with everything needed inc new bolt, clip and cip clips and are about 27
    Nov 2005
    UK
    1,688
    i need to get the tracking done anyway, infact i need to sort alot of stuff out
    wanted for 8L S3:
    Milltek system
    Ross_S4
    Aug 2009
    Dundee
    718
    Quote Originally Posted by mattyboy199 View Post
    Elsa does give you torque figures and tightening sequences where required however doesn't always tell you the tools you need. It does show the audi specific tools codes however won't say like "10mm socket, No2 phillips " etc...
    I got my cv boot kit from audi. they are cheap as chips and you get the boot, clips, grease, spring clip, and washers.
    If you get one elsewhere and dopn;t get the grease halfords do a big tub of it called cv grease, guess that is to avoid confusion...
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Anyone know the torque setting for the ball joint where it connects to the hub. I done mine up to tight I think because its split already.
    Nathan
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by S3 Nattie View Post
    Nathan
    No idea. Mine went to my standard of VFT...
    Homer Simpson
    thats me
    Sep 2004
    west yorkshire
    3,762
    two grunts and a moan normally does it lol
