AH FabricationsJMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 49 of 49
  1. #41
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    Quote Originally Posted by devan View Post
    Are these tie arms still for sale Dave? I think i need some after lowering my car.
    And this may sound stupid, but ive only ever seen rear tie bars for sale, how do i adjust the camber on the front wheels?
    Cheers!
    PM Dave mate. He still makes these and they are in very high demand.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  3. #42
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Cheers!
    thats done on the bottom ball joints on the front hubs. they slide in and out on the wishbones.only about 5mm in and out play. i dont know what that equates to in degrees though
  4. #43
    devan's Avatar
    Jun 2010
    118
    Ok cheers, yeah I wondered why the alignment holes seemed to be slotted when i replaced them, ill have to look into that because i had uneven tyre wear on the fronts before lowering.
    Just want to double check rear camber before i order a set.
    _____________________________________2010 Audi A5 Sportback S-Line ____________________________________
  5. #44
    Westy's Avatar
    Dec 2008
    17,272
    If your car has been lowered any more than about 15mm you'll need adjustable tie bars.
    Once you've got them done get the car 4 wheel aligned. About £100 from a tyre place and that'll sort you out.
    S3 Build Thread
  6. #45
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Cheers!
    Fronts give just over 1 deg neg camber max using the slots even if you open them slightly (not by much mind, 2mm or so max) which can be a ball ache to set on the alignment rig as the subframe needs to be cock on in the middle and not many places are prepared to go to such lengths to set it up for the little you get back...
    StaceyS3 has Ground Control camber plates on his S3... they look as though they could work ok..
    Ground Control - Camber/Caster Plate- VW (MK IV) A4 Chassis (Pair)
    More potential camber plates etc info here...
    VWVortex.com - MkIV Camber plate list
    <tuffty/>
  7. #46
    Westy's Avatar
    Dec 2008
    17,272
    <tuffty/>
    How much
    S3 Build Thread
  8. #47
    Dec 2011
    46
    how much are these s3 dave
  9. #48
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Quote Originally Posted by Logic_Dan87 View Post
    I would drop him a PM...
    <tuffty/>
  10. #49
    Westy's Avatar
    Dec 2008
    17,272
    <tuffty/>
    Now his PMs are working
    S3 Build Thread
Tags for this Thread
