Badger5Volks Autos
Results 1 to 8 of 8
    Julz.S3's Avatar
    Dorset
    48
    Question about Wiper Blades,.?
    Hi Guys, i need some new wiper blades, and i just want a direct replacement for the standard ones.But when i look for them on ebay they only come with one spoiler, and the pair i have on that the mo have two spoilers, does anyone know why this is ??...Thanks for any help.
    Alex C's Avatar
    Lizard, Cornwall
    2,603
    couldnt you just take the spoiler off the old ones?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I use these, and think they are brilliant....
    http://cgi.ebay.co.uk/FLAT-WIPER-BLA...item20acd1d189
    Homer Simpson
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Do you find the passenger side blade sits just off the window in the corner? The similar ones i had fitted before fitting the proper aero wipers did this.
    29
    www.wiperblades.co.uk
    Bosch Aero's sould do the trick.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by mk1chopper View Post
    No, mine are cushty dude, maybe your pass side one was a bit long?
    Homer Simpson
    Julz.S3's Avatar
    Dorset
    48
    I really wanted the standard ones, but with 2 spoilers.I have had a look at my ones and i dont think i can remove the spoiler,has anyone tryed this b4 ?????.Cheers 4 yr help.
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Nah correct size, if i remember correctly it was common, new blades may not do this now but when these first started appearing the passenger side wiper would sit just off the screen in the corner so when you wiped the wiper didnt clear at the end of the blade for the first bit but as the blade comes up it makes contact with the screen. I got my aerowipers from wiperblades.co.uk but when they needed replacing i got the aero kit from vagparts (before it closed). I think the aero kit is a worth while upgrade, it was about 60 iirc, but would recomend the above mentioned replacement aero wipers over standard wipers if you'd rather not spend a little bit more on the upgrade.
