Chris NottVolks Autos
    Mar 2010
    6
    a3 1.6 not starting after getting warm
    right when i go out 1st thing in the morning the car will start fine and when i come out of work later on, roughly 8hrs later it will start up fine, but when i stop for petrol or to go into the shops after it gets warm it wont start properly..
    the starter motor would engange the engine and turns it a little bit but then it just jumps out again, it will sometimes take like 5+ times of me turning the ignition off and trying to start it will it actually start, anyone got any ideas what it could be? thought it might have been the immobiliser being dicky but i thought that it wouldnt even try an attmept to start it... possible new starter motor needed??
    any help is much appreciated
    cheers
    dave
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    first get a VCDS scan
    http://maps.google.com/maps/ms?hl=en...,26.784668&z=6
    No Start
    – Battery - ECU, Fuel Pump Relay, Ground
    My guess is the Crank sensor, which is failing. Had the same issue, would start when cold, but when hot problems started
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Apr 2009
    24
    Sounds almost exactly like the issue I was having only the other day!
    Does the ASR (Traction Control) light come on?
    See http://www.audi-sport.net/vb/showthr...ght-on)-SOLVED!!!
    2002(52) 1.6 Sport
    Mar 2010
    6
    finesse - thanks for the info theres a guy local to me in bedford which shows on that map so will see if i can get hold of him
    johnone - i read your post earlier actually and thought it could be the same problem, but my car drives around fine when it is going and the asr light doesnt come on.. it could still be the crankshaft sensor though, not sure whether to just change it and see what happens, but rather someone just saying it could be that id like to find out myself if you know what i mean, but the thing is i dont have this vagcom thing so i got no way of checking it out.. btw was your car slightly misfiring at all on idle? before you changed the sensor of course..
