    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Knock - through steering wheel.
    Hi Guys.
    Today whilst driving over some cobbled roads, I noticed a knock through my steering wheel.
    Not sure weather its suspension related, or possibly something on the steering itself (uj??) However i Jacked it up to see if i could find any play having a pull around...But couldnt.
    Any ideas?.. Common problems?
    Thought possibly subframe mounts, as the rack bolts to the subframe... I think. But not sure how to test/check them.
    Any help appreciated.
    Callum
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Sounds suspension related. I would say its a bush of some sort. I changed my lower arm ball joint which used to knock quite bad but was fine when I jacked it up and checked for play.
    Some bushes wont show any signs of play unless they have a load placed on them so jacking up sometimes doesnt help. I would have a look at your lower arm ball joint.
    I didnt know we had subframe mounts.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Yeah, apparently its advised to change them for TT subframe mounts as there more solid.
    How did you diagnose your balljoint Nattie?.. Was it just the balljoint or complete arm?.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Mine used to knock pretty bad when going up into my drive, turned out to be the front wishbone bushes. Got them changed and all is good
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Well I kinda new what it was when I first heard it. If I when over a pot hole or rubbish tarmac I could hear a knocking sound around the wheel area and if a hit a nasty pot hole I could feel it through the steering wheel.
    The knocking used to be in sequence with the up and down movement of the wheel if you get me so I new it was something that was connected to the wheel / hub and thats the only thing.
    Ball joint is really easy to change and can be bought seperately. I only changed the ball joint and the knocking has gone, paid 22 something from Euro parts.
    fran-s3's Avatar
    1,090
    You're lucky Nattie, my knocking had the same symptoms as yours and turned out to be a shock absorber! Was a tad more then 22 lol. (and you have to replace in pairs!)
