Sky InsuranceAH Fabrications
Thread: Ecu removal
    Mar 2008
    76
    Ecu removal
    Hi guys, anyone know how to get the ecu off a 2001 s3. Ive taken the wipers and scuttle off, disconected the connectors and taken off the 2 10mm nuts that hold the cage but the rear of the cage is still stuck!! Any ideas????
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    I didnt have to undo any nuts round the ecu, just pulled it out, is a bit of a tight fit though.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Mar 2008
    76
    Thanks mate, i didnt want to pull it to hard incase something broke. Thanks, ill give it another go
    Sep 2009
    102
    Suppose it is similar to an A3, there should be a metal catch to the right of the ECU (view from front) that just catches the corner of the ECU housing which you need to just gently push away with a screw driver. The ECU should slide out easily...
    Audi A4 2.0TFSI Quattro S-line - Stock! (for now)
