JMB RetrofitsChris Nott
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Fitting blue tooth hands free
    thought it was about time so have bought a nokia car kit, will be fitting it myself, so was wondering whether anybody else has done same?
    I reckon that it should fit behind or above the glove box, HOW DO I GO ABOUT REMOVING IT?
    Will also need to get to the back of the head unit for ignition feed and auto muting feature (r these marked?), HOW DO I REMOVE THE H/U? I am assuming that once the pannels are removed from each side of the face that i will see holes for the pullers?
    So many questions .... any help appreciated
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Marcus
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Fitting blue tooth hands free
    If you are just looking for a place to mount a box, then it would be easier to mount it behind the drivers side dash panel. There is loads of room here and it is next to the fuse box, so finding an ignition feed is far easier.
    Heres how to remove the panel http://homepage.ntlworld.com/kevin.y...rimRemoval.pdf
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    cheers, will have a look this afternoon.
    Oct 2003
    up north...
    767
    the head unit usually has 2 or 4 small slots somewhere - these are usually next to a button using the same opening as the button in the facia with just a slightly wider slot, so can be difficult to spot.
    if you want to go the glove box route (i put my sony hcb30 bluetooth box behind the glove box sitting on the top of the fan for the aircon unit) you prise off the dash end panel at the left side, undo all the screws, and there are some screws inside the glove box along the top edge behind the door, and some under the bottom of the door.
    the box lifts away and you just disconnect the feeds for the courtesy light and airbag if fitted.
    if you are lucky, everything you need will be already going to the radio, so you can use an autoleads adapter or tap in to the wires and run them from the back of the radio slot to the space behind the glove box easily.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    thanks dunk, now i have two options [img]/ubbthreads/images/graemlins/smile.gif[/img]
    gonna use the HU features to support the car kit and use the car speakers rather than installing the additional one in the footwell.
    Just gotta get the lead (?) to connect it all together, will have a word with stealer 2morrow and figure out what i need to get.
