Sky InsuranceEM Tuning
    gumball b's Avatar
    [OLD SKOOL CRUISER]
    Oct 2009
    Harrow England
    72
    idle up and down and flat spots
    hi everyone,been ofline for a while. i was hoping i can get a reply to my it also has an unpredictable flat spot when you dont need it,its like it surges all of a sudden.i put a k+n panel filter in about a month ago and could this be the cause,im fitting a forge 007p tommorow to it and hope this may cure it a bit,i know the bosh one is not up to scratch..any advice from anyone i would be most greatful many thanks and good to be back....
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Hi bud, to check if your maf is faulty, unplug it and see if the idle is any better, if it idle ok with the maf unplugged you need to replace it. The k&n has probably caused it to go
    gumball b's Avatar
    [OLD SKOOL CRUISER]
    Oct 2009
    Harrow England
    72
    thanks for that mate,if it is that it will do it again i suppose if i have to get a new one. someone said to me not to do it coz of oil residue getting stuck to the maf, will try that tommorow,still gonna fit the d/v though hope that goes ok thanks again mate....
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    I had a k&n in mine didn't cause any issues, you could clean it first and see how it goes. It might be worth getting it checked via vagcom, might have other faults on it
