Results 1 to 7 of 7
    TIM66's Avatar
    Jun 2007
    isleofwight
    11
    HELP! Central Locking
    Hi Guys,
    Can anyone point me in the right direction to fix this problem?
    The unlock button on the remote key of my A3 only opens the drivers door and fuel cap. All other doors and boot remain locked.
    Any suggestions of what the problem is would be much appreciated.
    Thanks,
    Graham
    A3 2.0 TDI SE 2013
    flat out if in doubt
    stoke on trent
    149
    have you checked the blade in the central locking pump.if im right it should be the same as my s3.they are made of graphite and break very easy.i had a similar problem, the 2 doors would open but not the boot.got a new kit from ebay.this is the link item number 250608913569.this is the same guy i used.if you need to check yours, it should be located in the boot on the left side, behind the panel low down.you will no if is broke cuz it will be in bits
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    maybe you have the 1 touch feature. try pressing it again and see if the others unlock.
    Now to many mods to list! Lots of power, torque and Leather!
    TIM66's Avatar
    Jun 2007
    isleofwight
    11
    Thanks Ash,
    I will check that.How do I get the pump apart to find broken blade?
    A3 2.0 TDI SE 2013
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    if the pump was shot then the 1 door would not open would it!!
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Try pressing the unlock button twice in a row, maybe you have the setting to only unlock one door (security feature)..
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by ALPINE View Post
    Quote Originally Posted by nilz18t View Post
    3rd time lucky..... try pressing the button again as it sounds like the 1 touch feature!! ha!
