EM TuningChris Nott
Results 1 to 8 of 8
    Pat J's Avatar
    Getting there
    Jul 2009
    Nth Lincs UK
    64
    Which injectors for TDi
    I've got an A3 110/115 TDi which I've had remapped with the upsolute remap (140ish), it's also got a full Milltek turbo back exhaust system and I'll be fitting a green cotton panel filter shortly. When I had my Leon Cupra TDi I was told fitting larger injectors would help improve performance.
    Does anyone know which injectors I can fit to the A3 and what the part numbers are from a VAG dealer.
    All advice appreciated as usual.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    I don't know about diesel but on a turbo petrol engine you only fit larger injectors to support increased airflow from a bigger turbo... I can't see what gains you would get without the support of extra airflow and the mapping changed to suit... normally the map needs to be told it has the larger injector else they will just dump more fuel as the ECU will use the same duty cycle as it did for the smaller ones...
    You may want to try asking on the diesel forum as well mate....
    <tuffty/>
    MAD_Adamski's Avatar
    Jan 2009
    314
    no the chap is correct if i can find the website i will go look now i am thinknig of changing my injectors too as i have the same sec as above! i'll go look 1 min
    Jan 2009
    314
    http://www.kermatdi.com/servlet/-str...0--dsh-/Detail
    ok there you go, 20hp and 40LBFT upgrade! i am thinking of doing this...
    Jan 2009
    314
    altho i think these are going to be the best!
    http://www.kermatdi.com/servlet/-str...02-dsh-/Detail
    ruairi83's Avatar
    Dec 2007
    739
    ive a 90 bhp a3 and put 110bhp injectors into it and got it remapped and its sitting at 134.8bhp at the moment....
    Jan 2009
    314
    mine was a 110, has turbo back miltek, pipercross panel, smooth airbox, power rore remap so basically must be pushing 150hp with the uprated inj and if i added a front mount and pd150 turbo could look at a reliable 190hp....
    Jan 2009
    314
    well my injectors are ordered egr removal too! next for a front mount!
