Volks AutosEM Tuning
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Switched live wire?
    As subject where can I find a switched live wire to wire a component in near the stereo? (About 30-40Amp draw)
    Cheers!
    May 2003
    North West
    202
    Re: Switched live wire?
    Im pretty sure there wont be a switched wire that will allow you to get 30-40amps from it unless your going to use it as a switch on a relay and then get the main power feed directly from the battery.
    Best bet is usually the stereo or interior lights, have no idea of wire colours though.
    Mark
    Jun 2003
    World of my own
    9,813
    Yes, as Mark says, you need to wire in a 8 gauge (AWG) or bigger, fused cable straight to the battery, and use the remote on from the stereo to switch it.
    No one swiches a 30 amp connection, as the switch would have to be massive.
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Yeah I was on about using a Relay to the wire anyway.
    Are there any wires from the ignition that I can use?
    Jun 2003
    World of my own
    9,813
    There's a switched ignition wire to the HU, red with a white stripe. Some Audi's don't have this but you can pick it up from the fuse box. Look for fuse Radio (S-Kont).
