EM TuningJMB Retrofits
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    Questions to those that have fitted front ARB (S3's only)
    Recently purchased R32 front & rear ARB's. Fitted the rear last weekend & thinking about doing the front this weekend purely cause i have the time & will save a few quid. i ve done a little research on the net, but have a few questions (even found a guide).
    1. Did you replace the sub frame bolts, i understand the bolts are coated with thread lock or similar?
    2. Did you use a torque wrench on the above bolts or just man power ?
    thanks
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    martin g's Avatar
    [censored]
    somerset
    154
    I dont know myself but i have a question. torque wrenches do not facilitate in removing tough fixings so not sure why your comparing them with manpower?
    Torque wrenches are settable to a specific torque setting required by a machine builder to ensure something isnt too loose or too tight.
    Maybe you mean when doing them back up? to a torque setting or fitters eye? if so then I apologise
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    i think thats exactly what he meant
    Nov 2005
    UK
    1,688
    i m not comparing them, i m asking if i should use one when i do the sub frame bolts back up or should i just do them up as tight as possible (man power)
    just red the last line of your post exactly that
    wanted for 8L S3:
    Milltek system
