Results 1 to 10 of 10
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    LCR Brembo's on an S3...
    I'm going to fit new discs and pads all round on my S3 and just wondered if anyone has fitted the OEM Brembo front calipers to their S3 from the Leon CupraR? I looked at some discs online and they say the fit both S3 and LCR so do they both use the same diametre front discs??
    If anyone has done it what is involved? Is it a straight swap or is there any modification involved?
    Also if anyone has a good set of LCR Brembo's for sale then drop me a PM i could be interested
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Quote Originally Posted by SamiG View Post
    LCR fitted with Brembos are 323x28mm discs... S3 and non Brembo Cupras are 312x24mm IIRC...
    LCR Brembos are radial fit and will need brackets. You will also need the front brake pipes too.
    Bill at Badger 5 sells a kit that uses Brembo GT calipers and LCR 323mm disks... You are unlikely to find anyone selling theirs second hand on here tbh....
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    If you see a website listing same disks will fit LCR and S3, its a mystake.. a common one.
    Leon cupra and S3 share 312mm disks
    Leon Cupra-R runs 4-pot brembos and larger, thicker 323x28 disks..
    a full LCR brake system will fit onto an S3 however if you have the for them (Brembo Gt Junior kit is cheaper way of getting the same thing however)
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    So if i found a breaking LCR for examples sake, what parts would i need to do the swap other that calipers/carriers, disks and pads?
    Thanks for your help guys
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Calipers, pads, hoses, brackets, discs....
    Brake fluid would also be useful
    <tuffty/>
    gez
    S3 hunter
    Sep 2009
    Middlesex
    98
    ahh, now i had the understanding that S3 and LCR had the same hubs. so LCR brembos should fit straight on with LCR discs and pads and pipes. no brackets needed..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Quote Originally Posted by gez View Post
    AFAIK they share hubs but LCR Brembos are radial fitment and require brackets... S3 calipers have a carrier... different...
    As I said in the post above, LCR calipers, pads, hoses, brackets, discs are required to allow fitment to an S3
    <tuffty/>
    gez
    S3 hunter
    Sep 2009
    Middlesex
    98
    So LCR brembos have a bracket bolted to the hub and then calipers bolt to the brackets? So these can be got from the stealers. I thought the lcr brembos bolted straight to the hub. Might pop over to lcr.net nd ask around
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,358
    Well looking at what the experts above say the hub must be different, as if it was as simple of using the LCR bracket, more would do it rather than spending cash on bespoke brackets
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    The OEM LCR brackets are about 120 each and the LCR Brembo calipers are just silly expensive which is why Bill sells the Brembo GT jnr calipers and alloy brackets as it more or less the same gear but no where near the price tag of OEM LCR stuff...
    If you can get them from a written off car at a good price then all is good...
    Normal Leon Cupra uses same brake setup as S3 and TT, 312mm and as far as I am aware, same hubs etc.... Leon Cupra R came with Brembos and 323mm discs...
    <tuffty/>
