JMB RetrofitsSky Insurance
Results 1 to 13 of 13
    clacton on sea,essex
    217
    Audi a3 temp senor mabie
    Hi guys,strange this one i have left my car running outside for 10 mins or so,i will come out and it will be just under 90 or mabie about 45.
    When i give it a nice hard drive it will sit on 90 but if then i go to little roads back down to 45
    what could this be and how can i find the problem
    Jun 2003
    World of my own
    9,813
    Temp sender first as it's cheap and easy, then if that doesn't fix it it has to be thermostat, but the symptoms are the opposite of a stuck stat. If it's stuck open then it should reach temp idling, but drop on motorway.
    Alex Turner
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Could be the thermostat but more likely the temp sender. There is a way of checking the temp sender using the '49C trick'? I'm sure a search will bring it up...
    Edit: Also found here: http://www.wak-tt.com/tt/climatecontcodes.htm (works on a similar principal).
    Change it anyways mate, make sure you get the green top one which has superceded the old black coloured one.
    Thermostat change here: http://forums.audiworld.com/showthread.php?p=16925102
    Imteyaz.
    217
    wer can i get a temp sender from and have u a picture were this is thanks
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Look down the length of the oil level dipstick, you'll see a sensor there. The sensor can be had from your nearest Audi dealer or ebay, just search for A3 temperature sensor.
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    The temp sender is located at the side of the block (gearbox end), more info here: http://forums.vwvortex.com/zerothread?id=1287042 (pics in there too!)
    The thermostat is the one that is located on the left hand side of the dipstick tube.
    Imteyaz.
    217
    hi guys whats the first thing i should change then,also today just noticed only one of my fans work i can spin one but the other feels like its rubbing on somthing,also dose it realy matter that my car is between 0-90 will this corse any efect on the car atall thanks guys
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Can't help you on the fans as I know jack-poo about how they should work unfortunately, but I would change the temp sender first (easy 5 minute job) and failing that, change the thermostat (can be a pig of a job if you don't have the right tools). One thing I should have asked is have you had it scanned for any fault codes? If not, that would be a good starting point....
    Imteyaz.
    217
    yes had it scanned when i had a remap and it said coolent sensor,but then when wiped it never come back,have had it for two months or so and still not come back do you recon this is the temp sender
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    Quote Originally Posted by Imteyaz View Post
    I stand corrected - it was a while when I changed mine and I did both at the same time
    217
    Hi sorry didnt quite get that,what did u change at the same time thank you...
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    I changed both, the temp sensor and the thermostat.
    The thermostat controls the flow of coolant through the engine and it works by opening and closing depending on the coolant temperature.
    Temp sensor tells the ECU and your dash the current coolant temperature.
    Jun 2003
    World of my own
    9,813
    And yes it does matter that the car thinks it is running cool as the ECU will adjust timing etc accordingly so your car will be running rich and can lead to idling issues and stalling.
    Alex Turner
