AH FabricationsSky Insurance
Results 1 to 9 of 9
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,076
    whats the diameter of a standard s3 maf?
    as above as i seem to be only getting 189g on the liquid guage but boosts to 24psi on a stage 2????
    something is wrong somewhere ,,it goes like stink so im guessing i have a bigger maf and the values are out?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    If you are using the std air box then you have a std S3 MAF... they are nearly 3"...
    If you are only getting 189 g/s then I would imagine the MAF sensor is the culprit...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,076
    cheers, im using a bmc , would you still see 24psi though?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Boost and airflow aren't the same....
    Can still make boost and have poor airflow.... take tyres... no airflow, 32psi...
    Do you know if the MAF has been changed and when that was?
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,076
    i dont know, how old it is mate, i thought if it was boosting it has to be drawing air in at a decent rate, as like i say it goes fine...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Check for fault codes then do some third gear runs (using the MAF gauge on liquid) to see what max you get airflow wise... if its not around 200g/s or more then the MAF sensor may be the issue but I have seen engines being strangled by BMC type air boxes... the OEM airbox will flow 300bhp with no probs...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,076
    no fault codes, will try 3rd gear runs cheers, the car is supposed to be running at 298bhp with the hybrid ko4
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    298bhp is a little 'happy' tbh.... most I have seen is 220g/s through a hybrid before now... that wasn't putting out anything near the power you suggest...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,076
    could be.... thats a print out from apr after 4k of work with reciepts......luckily that was from previous owner last year
