Chris NottJMB Retrofits
Results 1 to 23 of 23
    Oct 2009
    11
    Audi S3 Sale and engine
    Hey,
    hope all are well!
    I am looking to sell my Audi S3 but before i do I was hoping to solve an issue with it.
    It seems to be running in limp mode I ve had it checked by Audi and the Maxium charge pressure is being exceded. Ive had the dump valve and air mass meter changed but its still down on Power.
    Audi are sure its not the Turbo but its shows an error in the engine maganement.
    Does anyone have any ideas?
    If i cant get that sorted on my own I would still consider selling it for a lower price as I am moving to London and will have no need for the car.
    See below for the pics i took in December also just had the new brakes and pads done and service.
    http://dl.dropbox.com/u/589453/DSCF0661.jpg
    http://dl.dropbox.com/u/589453/DSCF0668.jpg
    http://dl.dropbox.com/u/589453/DSCF0671.jpg
    http://dl.dropbox.com/u/589453/DSCF0670.jpg
    http://dl.dropbox.com/u/589453/DSCF0677.jpg
    http://dl.dropbox.com/u/589453/DSCF0680.jpg
    Mike
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Might be worth posting up the error code so the usual knowledge banks (Bill/Tuffty) can have a gander and offer some advice.
    Oct 2009
    11
    i dont think what I said about the turbo was clear.
    Audi are sure the turbo is fine...
    But there is an error being shown: for the Engine magament.
    I dont have access to the fault codes now. I would have to get it back on the VAGCOM
    JD09's Avatar
    Dec 2009
    3,080
    That's what I mean chap. Find someone with VAG COM, check what errors are showing (unless you have been told the code by Audi, who should really have then given you answer and solutions . . . !) and then post them up on here.
    fran-s3's Avatar
    1,090
    Nice looking motor mate, sure you won't have trouble selling it as it looks in top nick... Ming blue and cream leather go well...
    Oct 2009
    11
    hey thanks.
    right now im in two minds.
    thinking of putting it on Ebay for 3k "as is" rather than spend the difference just to get the higher resale...
    fran-s3's Avatar
    1,090
    No don't do that mate just post your error code on here and someone will suggest the problem. Failing that where are you? We can suggest some good audi specialists who will be able to diagnose it for you.... Why sell it for 2000 cheaper if it costs you 500 to sort, if that!
    Oct 2009
    11
    should be getting the fault codes today...will post hopefully
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    I'll give you 3k for it!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    looks lush with the cream .....
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    OK - this error is caused by too much boost being produced by the turbo.
    A couple of likely causes here. First and foremost, the N75 valve. This is the boost control valve. Try swapping out with a spare if you can. You should be able to get one from a breakers for testing.
    There are 2 pipes which connect to this valve. One of them comes from the charge pipe to the N75 valve, and the other goes from the N75 valve to the turbo's actuator. Check both of these hoses for kinks and splits. Pressure escaping from these hoses will mean the actuator doesn't open at the correct pressure, or at all.
    The actuator may be an issue here also.
    Finally, the MAP sensor may be the cause.
    The most likely are the first 2, the N75 and the hoses.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Without the correct and specific fault code it's hard to find the right article - however this will be somewhere close to being right: http://wiki.ross-tech.com/wiki/index...3/P1555/005461
    Homer Simpson
    Oct 2009
    11
    Thanks Very much. That last post was very helpful.
    Can anyone recommend anywhere in the North West (apart from Audi themselves) that could run through this and get it sorted so I can sell it in the condition I would expect to buy it in.
    I would rather go somewhere off a first hand recomend than just googling "audi"
    Thanks again!
    fran-s3's Avatar
    1,090
    Awesome GTI in Manchester - I hear their on the ball? (http://www.awesome-gti.co.uk) Can you name an area your in mate so we can further advise?
    Chugger
    North Devon
    2,716
    Quote Originally Posted by golf View Post
    Ha, Il go 3001
    you dont want to be doing that, that looks in very good condition for a prefacelift!
    Im surprising audi cant diagnose that.
    57 A3 2.0 TDI Sportback (140)
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by pixelpollen View Post
    Thanks again!
    Thats what the 'Thanks' button is for.... lol.
    Homer Simpson
    Oct 2009
    11
    OK.
    The car has been in at Awesome-GTi Manchester and they have diagnosed the problem.
    The Turbo has seized but they seem to think its in a position to be reconditioned. Also the engine lump is an AUM.
    I need to sell this car in its current condition as cash is tight and I'm moving to London shortly.
    I just had it taxed as well...The car drives but there is no turbo power as of this moment.
    for anyone interested then take a look at the pics below and call me 07929 860 269 to talk about it...
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Looks lovely mate, just like my bro's old one.
    You said it's an AUM lump? Weird - must of had an engine swap in it's life.
    What sort of money are you looking for? PM me if you want to chat.
    Homer Simpson
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    Good candidate for an uprated turbo conversion...
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    Seats are proper minging!
    2003 Audi S3 + Go faster bits
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by MintyS3 View Post
    I like them actually.... Still, each to their own as usual! lol.
    Homer Simpson
    Jul 2008
    Up North
    1,577
    I meant dirty! lol
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Ahhhhhh, sorry bud!
    Yeah, that they are! Nothing that a bit of Autoglym leather cleaner won't sort though.
    Homer Simpson
